spoon calipers
Old Feb 1, 2004 | 04:01 PM
luckypon7's Avatar
Default spoon calipers
i have a 98 GSR will the spoon calipers fit the GSR with 15" rota c8?
Old Feb 1, 2004 | 04:07 PM
Kendall's Avatar
I'm pretty sure the Spoon calipers are only for the ITR rotors. I think they should fit under the c8's with a wheel spacer though.
Old Feb 2, 2004 | 11:09 AM
mipawi's Avatar
Default Re: (Kendall)
if you want to put the spoon calipers just by itr rotors and take them to a machine shop and get them redrilled to 4x100 because the rotors are wider than the other integra models you can even use prelude rotors
Old Feb 2, 2004 | 12:01 PM
emissionsux's Avatar
Default Re: (mipawi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mipawi &raquo;</TD></TR><TR><TD CLASS="quote">if you want to put the spoon calipers just by itr rotors and take them to a machine shop and get them redrilled to 4x100 because the rotors are wider than the other integra models you can even use prelude rotors</TD></TR></TABLE>
But will the stock GSR caliper brackets work? Aren't they spaced a little different to compensate for the larger rotor?
Old Feb 2, 2004 | 01:25 PM
esponet's Avatar
spoon offers a big brake kit for the 4 lug models, kinda expensive but you get alot.
around $2500 you get spoon front calipers,rear itr calipers, 4 new rotors,(itr size but with the correct holes,new sets of spoon pads,and all the hardware needed to make it work.
they call it big brake conversion kit for eg6. just ask you nearest spoon dealer.
Old Feb 2, 2004 | 01:32 PM
Default Re: (esponet)
I'm wondering because I want to fit the calipers on my 92 Integra. I just need to know if the caliper brackets are all the same. Would it be cheaper to piece the kit together?
Old Feb 3, 2004 | 09:10 AM
mipawi's Avatar
Default Re: (emissionsux)
everything should fit
mr.refugee
Suspension & Brakes
Mar 26, 2013 09:02 AM
Drew17th
Suspension & Brakes
13
Aug 30, 2009 07:13 AM
Lthlintgra09
May 21, 2009 07:34 PM
tomman2001
Nov 6, 2007 06:44 PM
LOOKALIKe_eh2
Oct 26, 2004 09:35 PM
