rear strut
Old Feb 1, 2004 | 01:22 PM
ronald55555's Avatar
Default rear strut
I have a 96 4 door, replacing my rear strut/spring. The lower fork on my new strut is 5mm too wide, is it ok to put some washers to fill the space or drill a 5mm thick metal as a shim?
or will it explode while i'm driving it?
Old Feb 1, 2004 | 05:05 PM
doublejz's Avatar
Default Re: rear strut (ronald55555)
take an impact gun to that bitch, it should pull it in.
Old Feb 1, 2004 | 05:22 PM
Default Re: rear strut (doublejz)
5mm?!?!?!??? thats quite a bit to pull in.
And just a note to everyone, 96-00 EL rear struts are not compatible with EK rear struts, fronts are fine. I learnd this the hard way.
Old Feb 1, 2004 | 05:29 PM
5mm is a hair more than 3/16 of an inch btw.
Old Feb 2, 2004 | 06:36 AM
doublejz's Avatar
if you don't think it'll pull in, then get a bigger gun
Old Feb 2, 2004 | 06:49 AM
92b16vx's Avatar
Did you get struts for an EG?
Old Feb 2, 2004 | 02:24 PM
sweet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ronald55555 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 96 4 door, replacing my rear strut/spring. The lower fork on my new strut is 5mm too wide, is it ok to put some washers to fill the space or drill a 5mm thick metal as a shim?
or will it explode while i'm driving it?</TD></TR></TABLE>
i had to use washers on a setup before cause there was a slight gap between the fork and the CA bushing. i installed the right thickness/dimension washers in there and have never had a problem with it since. i preferred doing that instead of trying to bend the forks in too much to fit the arm.
evan221
Jun 9, 2009 10:41 PM
93JDMHONDA
Apr 6, 2004 04:08 AM
SL!M
Jun 13, 2003 10:28 AM
