Shift grinds
everyonce in a while (becinung more frequently now) when i shift from 1st to 2nd, theres a low grinding sound......not like a mis shift/bad clutch work, this is very low sounding, and his happening even when the clutch is all the way in.....i was thinking mayb the syncro on the 2nd gear collar is going bad and making improper contact???...i realy dont know all that much about trannies...anybody got a clue???
If its within warranty (your sig might not be your ride) have a technician at the delaer drive it and tell you....If so the warranty will replace hat they need to so you can shift smoothly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mazdillac »</TD></TR><TR><TD CLASS="quote">syncros prolly going, i had the exact same thing and i got new syncros put in and nows its fine</TD></TR></TABLE>
i heard thats pretty expensive?? how much for new synchros? my third gear synchro is all fucked up so im gonna need to do that soon... if its too much im prob just gonna go h22
well......after a more careful analyzation, its might be from teh cold....only seems to be happening when the shifter feels stiff (from the cold in teh morning).....im not gonna worry about it for now, but thanks for the heads up.....if it is the syncro, i bet its from all my 4->2 heel-toes at 40mph.....oh well thanks yall
who did you work and how much did it cost??
thanks agian yall.....im just pretty sure its the cold, but who knows.......ill check the tranny fluid when i change my oil......hmm......i could use an oil change soon too.......
I was experiencing the same thing while the temperature has been low...just shift slow and easy until the car has warmed up a bit...that is what I have been doing...and my OIL change IS tomorrow...so tranny fluid and check-up is coming also
weakGOODJunKieS.com
May 8, 2003 06:14 AM
