All motor H22 options
Old Feb 1, 2004 | 10:54 AM
SpeedingHatch's Avatar
Default All motor H22 options
Hey fellas,
I have an H22 hatch and I am going all motor. What should I look into, performance wise? Pulley's, Cams, raise compression, etc. Anything else?
I already have I/H/E, ACT clutch, and ACT lightened flywheel
Old Feb 1, 2004 | 12:50 PM
aeolus's Avatar
Default Re: All motor H22 options (speedinghatch)
if you plan the all motor route,raising compression would be very ideal,especially since higher lift cams and high compression go hand in hand...at least to make good power.Keep your stock crank pulley and i guess you can try changing your alternator pulley to a underdrive one while your at it.And if you dont mind a little vibration,you can remove your counter balance belt.That will make a big difference in acceleration.since its in a hatch,i seriously recommend getting at least the integra brakes up front and rear disk brakes.
Old Feb 1, 2004 | 06:58 PM
BolivianDc2's Avatar
intake
SMSP header
cat back w/ same quality as SMSP header
take off PS and AC
hondata s200
bore intake mani
type S cams
type S pistons
the list goes on and on....
Old Feb 4, 2004 | 05:49 PM
TTT
Old Feb 4, 2004 | 10:27 PM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedinghatch &raquo;</TD></TR><TR><TD CLASS="quote">Hey fellas,
I already have I/H/E, ACT clutch, and ACT lightened flywheel</TD></TR></TABLE>
Port & Polish
Portflow Valvetrain
Skunk2 Stage II or JUN Camshafts
STR Adj. Cam Gears
Sleeves (Golden Eagle or Darton)
11.5:1 - 12.5:1 Compression Pistons
Eagle Rods (Good Enough for All-Motor)
Old Feb 5, 2004 | 05:09 PM
Nice info, anybody else?
Old Feb 5, 2004 | 05:12 PM
satan_srv's Avatar
Default Re: (speedinghatch)
your question is so general how can anyone answer it?
If you want to raise compression, Type-S pistons and milling the head is your only option unless you want to sleeve the block.
Old Feb 5, 2004 | 08:34 PM
Default Re: (satan_srv)
Just trying to get ideas, thats all
Thanks for the input
Old Feb 6, 2004 | 12:24 AM
chaudanova's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedinghatch &raquo;</TD></TR><TR><TD CLASS="quote">Just trying to get ideas, thats all
Thanks for the input</TD></TR></TABLE>
Check the link in my sig... you can see my h22 build and use those ideas if you'd like
Old Feb 6, 2004 | 01:19 AM
G-money's Avatar
Default Re: (chaudanova)
hondata s200, good header, CAI, take the secondaries outta the manifold (shorter runners ) i'd put a zex kit or wet kit on it, the motor will take a 100 shot easy....i dipped 11's w/ 75 zex kit, act clutch, the manifold trick, Cold Air, slicks in a full interior dx hatch!
Old Feb 6, 2004 | 05:50 AM
Default Re: (All MTR TODA HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All MTR TODA HATCH &raquo;</TD></TR><TR><TD CLASS="quote">hondata s200, good header, CAI, take the secondaries outta the manifold (shorter runners ) i'd put a zex kit or wet kit on it, the motor will take a 100 shot easy....i dipped 11's w/ 75 zex kit, act clutch, the manifold trick, Cold Air, slicks in a full interior dx hatch!</TD></TR></TABLE>
wat are you talking about? sealing off the secondary intake runners? they are the short ones.....
all motor means no nitrous.....
Old Feb 6, 2004 | 07:56 AM
JDogg's Avatar
Default Re: (BolivianDc2)
he is talking about removing the butterfly plate. we picked up gains everywhere doing this. we did it on the dyno tuned before and after.
how much power do you want, properly tuned jdm h22 with i/h/e and type S cams should make around 200hp.
as for s2s2's... i havent really seen anyone get good gains from those. a guy running almost the exact same setup as us only made 200 with s2s2's we are doing that with type s cams and an intake that fits inside the throttle body
Old Feb 6, 2004 | 11:20 AM
G-money's Avatar
Default Re: (JDogg)
[QUOTE=JDogg]he is talking about removing the butterfly plate. we picked up gains everywhere doing this. we did it on the dyno tuned before and after.
yeah...and all i was saying about the NOS kit was that was all i had on it and it dipped into the 11's easy...duh....Thats another option if he wanted to go that route and it's cheap
Old Feb 6, 2004 | 05:29 PM
meanEG's Avatar
you can spend a lot of money on yours like mine and get 205. i spent around 12 grand or more on the engine and trans. i am going through round 2 this time and expect to see the real power.
Acidcrakker
Sep 15, 2007 08:36 AM
doubleturkey!
Jul 20, 2006 03:13 AM
exratedaccord93
Jul 10, 2006 04:22 PM
Turbohatch
Jan 26, 2002 10:44 PM
