loud bang and then...... (cable b16 tranny problems continue)
Old Feb 1, 2004 | 09:16 AM
riceboyEFsi's Avatar
Default loud bang and then...... (cable b16 tranny problems continue)
i heard a loud bang and then the car died , started it right back up and couldnt get it in gear. The clutch is about a month old . The tranny was installed the same time as the clutch (thanx HMO ) At time of instalation honda m/t fluid was used. I was also hearing alot of grinding and whining noises . Any ideas as to what could have exploded
Old Feb 1, 2004 | 09:22 AM
Patch's Avatar
Default Re: loud bang and then...... (riceboyEFsi)
Possibly the diff. Either way, if it wont go into gear with the car on or off the tranny needs to come out. Pull it out, and either take it apart and fix it or just sell it as is.
Old Feb 1, 2004 | 11:45 AM
virginia_dude's Avatar
Default Re: loud bang and then...... (Patch)
If the case and/or internals aren't all damaged you will be lucky, start looking for another gearbox.
Old Feb 1, 2004 | 05:08 PM
doublejz's Avatar
Default Re: loud bang and then...... (virginia_dude)
i have blown a clutch up, was riding the pedal had a big boom, tires locked up and stalled. all it was, was a blown up clutch. You make have lucked out who knows
Old Feb 1, 2004 | 06:07 PM
smokey2.0's Avatar
Default Re: loud bang and then...... (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">i have blown a clutch up, was riding the pedal had a big boom, tires locked up and stalled. all it was, was a blown up clutch. You make have lucked out who knows</TD></TR></TABLE>
or you could have blown, one of the mainshaft's bearrings! you'll have to open the tranny case, to find out the real reason why the tranny did what it did
Old Feb 1, 2004 | 06:11 PM
Patch's Avatar
Default Re: loud bang and then...... (smokey2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">
or you could have blown, one of the mainshaft's bearrings! you'll have to open the tranny case, to find out the real reason why the tranny did what it did </TD></TR></TABLE>
I beleive you are correct, but he can drain the fluid and see if any metal gear chunks fall out before he pulls the tranny.
miamiboy91
13
Jan 8, 2009 04:40 AM
Manolo
18
May 18, 2005 09:21 AM
four-eyez
May 1, 2005 11:59 AM
CRX16T
Nov 7, 2004 07:34 PM
Loaded Butane
16
Aug 20, 2003 02:31 PM
