Locked tranny after TOB replacement
Old Feb 1, 2004 | 09:12 AM
b18_coupe's Avatar
Default Locked tranny after TOB replacement
I have a coupe with a b18-b1 engine. The TOB was dieing, so I dropped the tranny to replace it. The clutch was still new so didn't even bother taking the assembly apart. Install was straight forward, I followed the haynes manual. Yesterday when I was reattaching the change rod to the shifter, I was able to move the change rod back and forth like how you would be able to shift with the engine off. Well today, i pressurized and bled the clutch system. Now the tranny won't engage with the clutch depressed or not (I didn't bother turning the engine on). The change rod is just locked now, and I can't seem to figure out what the problem is. All I did was drop the tranny and replaced the throw out bearing, so I can't see how I could have messed something up. Any ideas of what might have went wrong?
gisserhatch
Sep 4, 2006 12:45 PM
gisserhatch
Sep 3, 2006 05:24 PM
b18_coupe
Feb 3, 2004 05:15 PM
Juantay19
Apr 5, 2002 04:37 AM
