supercharged Gsr in 91 integra, how?
Old Feb 1, 2004 | 08:34 AM
loganb18c5's Avatar
Default supercharged Gsr in 91 integra, how?
How would i go about dropping a 95 supercharged gsr motor in to my 91 integra. is it worth the trouble?
Old Feb 1, 2004 | 08:40 AM
..::91TEG-G2::..'s Avatar
Default Re: supercharged Gsr in 91 integra, how? (loganb18c5)
i dont think there will be belt clearance.. but i might be wrong.
cuz i looked in my 91 to see if i could.. and it looks to cluttered back there but then i might be wrong..
Old Feb 1, 2004 | 09:00 AM
math labs's Avatar
there are 2 g2s that are supercharged, they are rising on g2ic.... but, it required a lot of custom fabrication. its definitely not worth the time or money..... hit the search button on g2ic and look for [supercharging]
Old Feb 1, 2004 | 09:32 AM
Kendall's Avatar
It can be done, but I don't think it's really worth it. You can build a turbo LS that makes a lot more power for less money, or you could buy a hatch and drop the supercharged GSR motor in it for a better power to weight ratio.
Welcome to Honda-Tech.
Old Feb 1, 2004 | 09:42 AM
loganb18c5's Avatar
Default Re: (Kendall)
if you dont think supercharging is worth it what is another way to get good reliable power out of my Gsr
riceball777's Avatar
i think it cant be done with out a lot of custom fabrication
the firwall it too close to the im
the engine bay in a g2 is way too small
Old Feb 1, 2004 | 10:33 AM
Kendall's Avatar
Default Re: (loganb18c5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loganb18c5 &raquo;</TD></TR><TR><TD CLASS="quote">if you dont think supercharging is worth it what is another way to get good reliable power out of my Gsr</TD></TR></TABLE>
It all depends upon the condition of the motor and what goals you have. If you are more of a drag racer, and the engine is in good shape, then consider a turbo. If you are into autocrossing, consider a good rebuild with higher compression, a good valvetrain and decent cams. It all depends upon what you want.
TheIVJac|{al
Nov 15, 2013 04:26 PM
ENJOI
May 11, 2004 12:18 AM
IntegraFanatic
Apr 8, 2003 11:40 AM
comptechgsr
Jul 25, 2002 11:40 PM
