How many plugs go into????
Old Feb 1, 2004 | 07:00 AM
DriveSideWays's Avatar
Default How many plugs go into????
how many plugs go into the back of your gauge cluster? because there are 4 slots but on 3 plugs... i think. i changed my whole dash in 10 degree weather and had to rewire everything there and i only found 3 plugs... can someone help please!
Old Feb 1, 2004 | 08:38 AM
Savv's Avatar
Default Re: How many plugs go into???? (DriveSideWays)
Just 3 plugs, NOT four!
If you are looking at the back of the cluster, the yellow plug goes on the top left, then there is a blue plug that is connected to a shorter wire and and that goes in the hole right near the yellow plug. Then the blue plug on the longer wire goes in the hole on the bottom right side, then you have a final hole like in the middle right and nothing goes in there.....I can't answer why but I know nothing plugs in there, I have switched my cluster so many times so I think i can do it blindfolded now!
Old Feb 2, 2004 | 04:57 AM
thanks wildone
jdmjin
Sep 26, 2012 07:44 PM
ef92b
23
May 20, 2009 11:49 AM
DailyBlown
Mar 7, 2005 10:21 AM
FUP23
May 24, 2002 05:03 AM
DB8
Oct 31, 2001 06:35 PM
