HELP...integra dash in, but can't wire it probably...what can i do now?
the cluster part is not working now, everything seems fine to me, but when i plug it back in, the cluster part is not working, the speed meter, tachnometer, oil temp, gas tank, nothing is working.....i am now stuck in the middle(can't even put back the stock one now), does everyone use the integra harness or just modify their stock civic one? and if you use the integra one, is it that the "green" and "blue" plugs will plugs right in???
Thanks in advance
Thanks in advance
Re: HELP...integra dash in, but can't wire it probably...what can i do now? (DB8)
well, are the plugs the same? if so you should re-arrange the pins. when i had and ITR cluster in my hb, 2 plugs from the civic fit the ITR but there was an extra plug left. i had to get integ plugs and reset the pins.
EGRhatch
23
03-27-2008 05:36 PM
hadehatch
10-20-2004 07:55 PM
FUP23
05-24-2002 05:03 AM
