Help with my GSR motor
Old Feb 1, 2004 | 02:08 AM
sleeperek's Avatar
Default Help with my GSR motor
ok heres the problem...the car idles fine but when you gas it theres a knocking sound coming from the head or block but i'm not sure where its coming from...a loud knocking sound...please help...I need your response on what you think it is....I need your advice so i can fix my car before i go home....
Old Feb 1, 2004 | 02:17 AM
typeRSXS's Avatar
does it sound metallic?
Old Feb 1, 2004 | 11:00 AM
sleeperek's Avatar
Default Re: (shupaGSR)
i think so....its sounds like there maybe something loose in the valve train but it also sounds like it might be coming from the block....
Old Feb 1, 2004 | 11:07 AM
JMod's Avatar
Default Re: (sleeperek)
maybe take a video or soundclip perhaps? That would help out bigtime if u can get either.
Kendall's Avatar
Sounds to me like a rod bearing is going out.
Old Feb 1, 2004 | 05:19 PM
sleeperek's Avatar
Default Re: (Kendall)
I think its a rod bearing also....Cause i let the car idle for about 40 minutes and the knocking go worst and the motor is idling low now(about 500 rpm)....and you can hear the knocking noise even when its idling now..yesterday the motor was fine when idling..but now u hear the knocking at idle....so what do u guys think...still need your help...
Old Feb 1, 2004 | 05:56 PM
Stewie's Avatar
check your oil pressure.
Old Feb 1, 2004 | 07:26 PM
Passaudi1.8t's Avatar
New User
Default Re: (Mac8008)
Def sounds like a rod bearing. I just had the same thing happen to me. I thought I might have bent a valve but once I removed the head and saw that everything was 100%, it was easily ruled out as a rod bearing. Always check your oil!
Old Feb 1, 2004 | 07:40 PM
sleeperek's Avatar
Default Re: (Dr.FeelgooDC2)
So did you change out the rod bearings only or did it do any damage to the crank or rods? AlsoDo u guys think it might be a bad oil pump??????Will a bad oil pump make this kinda sound...the sound seems to be coming from under the cyclinder number 1..thats why i thought that it might be the oil pump...let me know
Old Feb 1, 2004 | 09:02 PM
New User
The noise in my motor was also coming from the #1 cylinder. The oil pump wouldn't necessarily make any noise... except your rod bearings when it's not pumping enough oil throughout the motor to keep it properly lubed.
Old Feb 2, 2004 | 10:19 AM
sleeperek's Avatar
so did u fix urs already?????....I think I over torque the rod bearing caps and the main bearing caps...cause after i assemble the motor.....the crank was hard to turn...i mean hard....i had to use a long *** breaker bar to get that damn thing to turn....I thought it was fine but i guess i was wrong....but oh well i guess i learn my lesson....
Old Feb 2, 2004 | 05:47 PM
D@nnY's Avatar
cehck the oil for metal i would def drop the oil pan and pop the rod caps and check the bearings.If its that you porbably need a new crank or have yours polished.do not even start the car or your gunna kill your motor
Old Feb 2, 2004 | 05:48 PM
D@nnY's Avatar
Default Re: (GSRT37)
if your oil was really dirty that would cause it. how did it happen?when did it start?
Old Feb 2, 2004 | 06:05 PM
sleeperek's Avatar
Well i put the motor together myself.....I over torque the main caps and rod bolts by 10 ft-lbs...
092eg6
14
Mar 28, 2010 09:18 AM
91integraLSVTEC
Sep 21, 2009 09:19 PM
jdmstyleg
Sep 8, 2009 04:30 PM
kozzy00
Sep 8, 2007 02:52 PM
peakboosth22
Apr 1, 2007 01:25 PM
