F*cked Up My Seat, Twice!!!
Has anybody gotten a snag in their seat? It is not on the suede(sp?) but on the center section of the seat. I think it was caused by the zipper on my bookbag. I am lost on what to do to fix it... I thought about using a lighter to burn the snag material down and to the normal height and to hopefully stop it from getting worse but dont want to have a burn mark on my seat.
Anyone have any suggestions? I would take a pic of it but dont have a digi on hand.
I feel ya, man... My sister's big honkin' wedding ring tore a hole in my passenger seat cushion. It's a little tear/pul about 1cm wide...
Grrr... and I see it every day.
To fix it... seat would have to come out. Cover would come off cushion/seat. repaired from the inside out (I mean, it's only fabric). Cover reinstalled. Seat reinstalled. Too much hassle right now...
Besides, gives me the impetus to get JDM Recaros (as if I need any more). Question is... red or black?
sux about the snags
no rings, pens or any other sharp objects allowed in my car
V: A guy I know is selling his SRDs (black) out of his gsr b/c he needs some $. He's had it for about 10months. Let me know if you're interested
What kind of material is that? I think that I am going to call the local uphoseltry shop and see if they will look at it and give me a price quote.
Thanks for the help.
My passenger seat has one, i made the mistake of cutting it off, it hasn't unraveled that much, but it's a noticable hole...i may see if i can get it fixed under warranty, if not, when i put the sparco in i'll probably swap the drivers seat one.
I feel your pain. No problems with my seats, but I punched a hole in my headliner accidentally a few months ago. I try not to look up there. No suggestions for a seat fix. Sorry to hear about it.
Yeah, I had the same thing happen on my passenger seat. If it's just a snag on the material, like it pulled one of the "loops" up, then you should be able to take a needle and kind of pull the thread around the one that's snagged. Get what I mean? Just try to tighten up the loop that got snagged by pulling out the other ones around it a little. Hope that helps. Or you could just buy a replacement seat.
I kind of have a unique issue with the fabric on the drivers seat: On the seat bottom(where you sit) right where my wallet sits in my right back pocket that fabric is physically "worn" in pretty bad. Kind of matted down and almost frayed a bit. You can tell it's shaped basically like my wallet. I think it's from my few times drag racing and Also autocrossing I assume. You see, my right leg/foot is really rigid while I'm racing since I'm so content on mashing the gas pedal through the floorboard
So alot of wear and tear is transferred through my ***:0) to the seat. Anybody else have the "wallet" issue? Well, I don't keep my wallet in my pocket while driving the R anymore
M
M
