turbo itb's
Guest
Posts: n/a
yes I said turbo itb's would this be possible I was thinking about this all last night if you made a custom plenum around your velocity stacks could this work.
let me know what you guys think.
would there be any benifits to this?
Modified by DC-2R at 8:47 AM 2/1/2004
Yea, you can make ~700whp street car with a Victor X manifold (or even any other decent FI manifold), so why change that... Don't know if it would benefit you in any way or not... We're working on a twin TB manifold for Brian's car but that's just to screw around with... Who knows if there will be any gain... Just my $0.02
Modified by Kataku2K3 at 12:52 AM 2/1/2004
I don't think it would be too difficult even with tuning. Once you close the ITBs then you've pretty much created an Intake Manifold.
It would be something worth doing if you already had a set of ITBs and no one would buy them. (They're pretty expensive, trust me I know.) I say go for it.
i was thinkin bout copyin the 4g64 intake header design and bringing that into 2 throttle bodies that are billet replacements for chevy tpi 350's, then i woke up and relized it would take forever to fabricate. i am using an 80mm custom tb on my new build....90 degree elbow off my itr manifold. should look real nice and give some extra hp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge »</TD></TR><TR><TD CLASS="quote">ITB for is for all motor, not turbo, not even worth it.</TD></TR></TABLE>
who makes these imaginary rules that its for all motor only? i guess nissan is stupid since they have ITB's on the skyline and the sr20 GTi-R motor. worth it? probably not. for all motor only? thats what ignorant people say
IMO, there's a difference between being innovative and being cost conscious. If there's significant gains acheived through itb's then go for it. Frankly, on a boosted motor, the significance of itb's are small and not cost effective unless you're trying to extract as much horsepower as humanly possible. There's so many more ways to increase output such as toying with compressor size that'll be more cost effective. Unless you've maxed out all your other components, I'll stick with something more conventional.
Sam
Sam
Since its been awhile since this has been brought up again in FI im bringing this post back from the dead.
A lot of good info here.
From doing my own research and reading i dont really think the gains, if any, are worth the fabrication on a honda motor.
some one already said it but once you put the plenum on it would be like you have a normal intake manifold with short runners depending on how long you made the runners off the plenum ( i would think no proof..)
i agree,
even though it would be benificial no matter what...cause if you have each cylinder getting as much air as it needs, because they are all different....but in a turbo charged vehicle your forcing the air....N/A the motor has to ingest it...thats why the imaginary rule of ITB's are for all motor comes from...its more benificial to these motors....on turbo cars im not sure if the benefits are high enough to justify the time involved...
and the other thing is it has to have some sort of manifold before them...like the picture above.....which in turn basically makes it like a regular manifold setup....cause its a mass of air the engine is ingesting from...instead of 4 individual inlets that it gets what it needs..
but hey im always into new things...it could be more beneficial than we all think....we just need proof..
if you have the time, the energy, patience....i would say do it...thats the only way to tell
I think the idea behind ITBs is response, not power. When you hit the gas, the air goes right into the cylinders, and doesn't have to go 8-20 inches, or whatever the distance is, with a single TB set-up. I don't think tuning would be that bad, but I'm not sure it's worth it as a $/hp/response ratio for most people. However, I was at the junkyard and say some incredibly tiny TBs that I could almost reach my thumb and index-finger around, so those would make an economical solution
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC-2R »</TD></TR><TR><TD CLASS="quote">those are some sick *** welds.</TD></TR></TABLE>
TIG
TIG
