what else should i replace while changing headgasket
Old Jan 31, 2004 | 07:06 PM
jeremy.'s Avatar
Default what else should i replace while changing headgasket
any other parts that i should change out since my headgasket is getting swapped besides head studs? i might as well do as much possible while it is off
Old Jan 31, 2004 | 08:46 PM
2FastxEg's Avatar
dual valve springs and retainers
Old Feb 3, 2004 | 09:36 AM
jeremy.'s Avatar
Default Re: (2FastxEg)
what other gaskets or parts should i replace?
Old Feb 3, 2004 | 09:49 AM
acy76's Avatar
Default Re: (ek_jeremy)
If the head gasket was blown, you might want to have the head checked for warpage. Depending on the condition of the head, you could do the valve seals, cam seals, etc. (and also check the valves, seats, springs - general refresh). Minimally I'd do the manifold and valve cover gaskets along with the head gasket. Add a thermostat and gasket too if it needs them.
Old Feb 3, 2004 | 10:14 AM
virginia_dude's Avatar
Default Re: (acy76)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acy76 &raquo;</TD></TR><TR><TD CLASS="quote">If the head gasket was blown, you might want to have the head checked for warpage. Depending on the condition of the head, you could do the valve seals, cam seals, etc. (and also check the valves, seats, springs - general refresh). Minimally I'd do the manifold and valve cover gaskets along with the head gasket. Add a thermostat and gasket too if it needs them.</TD></TR></TABLE>
I second that, Taking it appart is a pain do as much as you can afford while you are there.
yblegal
Dec 1, 2010 09:53 AM
jyacoba2009
Nov 23, 2009 08:25 PM
prettylew
May 2, 2008 07:35 PM
98GSRDC2
Mar 5, 2007 10:13 AM
kKdARIAN
Nov 4, 2003 08:02 AM
