VTEC OIL FILTER
Old Jan 31, 2004 | 03:22 PM
Mikizzle's Avatar
Default VTEC OIL FILTER
Ive tried and search but founnd nothing, i was wondering if putting a 03 civic and rsx type-s oil filter does any good to a 95 gsr. IF its any benifical.
Old Jan 31, 2004 | 03:27 PM
oMek's Avatar
Default Re: VTEC OIL FILTER (grn4drgsr)
i use a 02 rsx tyoe s oil filter and its alot smaller than other filters ive seen. it works fine and some people say it gives you a higher oil pressure. if im correct honda now only sells 1 type of filter that fits the b/h/k series motors
Old Jan 31, 2004 | 03:49 PM
kablamo's Avatar
Default Re: VTEC OIL FILTER (oMekoneDC2)
i doubt it.
what kind of improvements in performance are you hoping to get from a different oil filter? assuming it is a different filter (i'm not sure it is), is it worth a new engine to get slightly better oil flow? probably not...
Old Jan 31, 2004 | 04:05 PM
purplegsr's Avatar
Default Re: VTEC OIL FILTER (kablamo)
You can use the newer, smaller OEM filters, no big difference. If you want to stick with the older, bigger style, get the OEM filter for the S2000. Both have higher pressure, and supposedly it does not effect performance or reliability at all.
Old Jan 31, 2004 | 04:33 PM
Mikizzle's Avatar
iC, so pretty much i can use 03 smaller filter on a 95 gsr rite? thanks alot
Old Jan 31, 2004 | 04:44 PM
1998_4dr_gsr's Avatar
Higher pressure? why not just stick with the proper size and what the recommendation requires? I mean will it last longer or give you more hp with the smaller sized filters?
Old Jan 31, 2004 | 04:46 PM
JChcmax's Avatar
I have used a smaller oil filter from Honda. I heard it's supposed to maintain a oil pressure in VTEC, without dropping oil pressure. I can't tell.
Old Jan 31, 2004 | 05:40 PM
4U2NV's Avatar
Default Re: VTEC OIL FILTER (JChcmax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JChcmax &raquo;</TD></TR><TR><TD CLASS="quote">I have used a smaller oil filter from Honda. I heard it's supposed to maintain a oil pressure in VTEC, without dropping oil pressure. I can't tell.
The "new" oil filters are made by three different companies... Filtec, who makes the old "larger" ones, Honeywell, and Fram as see on the one pictured above... So if you do decide to use the "new" style, make sure the parts guy gives you one made by Filtec or ask specifically when you go in...
Old Jan 31, 2004 | 05:46 PM
LSvtec03's Avatar
the new filter is not used for all b/h/k series. i hear people have problems with using k-series filters on b-series because the rubber seals arent the correct size. the new filters also use an element made by fram, which is lesser quality. i use the s2000 filter because they use oem jdm honda which was the best tested filter element and still has correct fitment.
Old Jan 31, 2004 | 05:47 PM
LVStreetWhore's Avatar
I went to Honda dealer and they gave me a smaller filter. I have to ask twice because I was used to getting the bigger ones. They said they discontinued the bigger ones and it should not affect car performance.
Old Jan 31, 2004 | 08:17 PM
Tweakmeister's Avatar
Default Re: VTEC OIL FILTER (LVStreetWhore)
smaller ones boost pressure...although I don't know if it's in bypass mode more now....just have to trust Honda in its decision.
Old Jan 31, 2004 | 08:21 PM
Dan GSR's Avatar
Default Re: VTEC OIL FILTER (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">smaller ones boost pressure...although I don't know if it's in bypass mode more now....just have to trust Honda in its decision.
yup thats exactly why you will get more pressure
thats why i go with an oversized filter
redDAinteg
Sep 3, 2007 12:19 PM
silentdeath12886
Dec 18, 2006 04:04 PM
EG8Master
17
Sep 30, 2006 04:14 AM
TypeRuz
Oct 13, 2003 11:53 PM
Outsane
43
Sep 14, 2003 10:46 PM
