LS Vtec Turbo buildup, Like some info on others setups, times, #'s. Reliability??
Old Jan 31, 2004 | 02:26 PM
Spooled1.6L's Avatar
Default LS Vtec Turbo buildup, Like some info on others setups, times, #'s. Reliability??
Very interested in this instead of spending all that extra cash on a gsr block to get the same results. iv seen big numbers and would just like to see and hear first hand from people who have fully built ls/vtecs and how they feel about its reliability vs. a Gsr Block. And if they have any MUST DO tips to keep it safe.
Thanks alot
Brad
Old Jan 31, 2004 | 02:29 PM
93LSivic's Avatar
Default Re: LS Vtec Turbo buildup, Like some info on others setups, times, #'s. Reliability?? (Spooled1.6L)
Dont be misinformed about being able to rev it like a gsr just cause it has a vtec head.
As long as its built right and tuned right it can be very reliable. If its mistreated and not tuned properly it wont last long (as with any motor).
Old Jan 31, 2004 | 02:32 PM
baphomet's Avatar
Default Re: LS Vtec Turbo buildup, Like some info on others setups, times, #'s. Reliability?? (93LSivic)
Why not rev it like a gsr? Rod bolts? Girdle? Surely not the slight increase in stroke.
Old Jan 31, 2004 | 03:10 PM
RedTegLS's Avatar
Default Re: LS Vtec Turbo buildup, Like some info on others setups, times, #'s. Reliability?? (slashDEVslash
I am sure there is a reason why LS's only rev to 6900 and GSR's rev to 8000.
Old Jan 31, 2004 | 03:15 PM
93LSivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slashDEVslashNULL &raquo;</TD></TR><TR><TD CLASS="quote">Why not rev it like a gsr? Rod bolts? Girdle? Surely not the slight increase in stroke.</TD></TR></TABLE>
Because the whole LSvtec concept is to put a better flowing head on a motor that will normally create more torque at a lower redline.
Although i rev my LSvtec to 9500. Then again, its being parted and Im going straight gsr now.
Old Jan 31, 2004 | 03:26 PM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedTegLS &raquo;</TD></TR><TR><TD CLASS="quote">I am sure there is a reason why LS's only rev to 6900 and GSR's rev to 8000. </TD></TR></TABLE>
Yeah it is because of the LS head and maybe rod bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">Because the whole LSvtec concept is to put a better flowing head on a motor that will normally create more torque at a lower redline.
Although i rev my LSvtec to 9500. Then again, its being parted and Im going straight gsr now.</TD></TR></TABLE>
Better flowing head, better cams, better valve train. Which equals power at higher RPM than the LS had with out the vtec head. I don't see what is wrong with reving a LSV like a GSR if you change out the weak parts. (Rod bolts) Am I missing something? Please let me know if there is a reason I don't know about.
Old Jan 31, 2004 | 04:59 PM
Chrome Pipes's Avatar
My LS/VTEC has had no problems so far. REAL low budget build: Stock LS block and stock B16A2 head with an InlinePro headgasket in between. 356 whp/ 257 tq, 11.61 @ 120 in a 99 Si.
Click on the link for more on the setup:
http://www.gtrmotorsports.net/bios/jaybio.html
Modified by Chrome Pipes at 9:10 PM 1/31/2004
Old Feb 1, 2004 | 08:29 PM
baphomet's Avatar
Better flowing head, better cams, better valve train. Which equals power at higher RPM than the LS had with out the vtec head. I don't see what is wrong with reving a LSV like a GSR if you change out the weak parts. (Rod bolts) Am I missing something? Please let me know if there is a reason I don't know about.</TD></TR></TABLE>
Old Feb 1, 2004 | 08:37 PM
Silverbeast's Avatar
I had no problem revving mine to 9k with the supercharger. Then again this was with the gsr girdle, arp bolts, and some solid stock sleeves
Now with the turbo im revving to 8400 and no problems.
qpzm12
May 24, 2011 11:54 PM
touintegra1
Jul 24, 2007 04:55 PM
808babooz
25
Feb 8, 2007 12:53 PM
AllMotorCrxRACECAR
Jun 22, 2005 02:30 PM
sikcivic95
54
Dec 1, 2004 11:48 PM
