TECH - fuel filter question with diagram
Old Jan 31, 2004 | 11:06 AM
Philip's Avatar
Default TECH - fuel filter question with diagram
Take note of this small diagram:
Question:
Does the hole in the banjo bolt (top circle) have to line up perfectly with the line coming in (second circle)? I torque down the banjo bolt to 25 ft-lb as required and it seems the hole doesn't line up exactly with the incoming (outgoing?) fuel line.
Thanks!
Old Jan 31, 2004 | 11:08 AM
CivicSiRracer69's Avatar
Default Re: TECH - fuel filter question with diagram (Philip)
no it doesn't
Old Jan 31, 2004 | 11:10 AM
King Tut33's Avatar
Default Re: TECH - fuel filter question with diagram (civiksiracer1)
I know I didn't worry about any holes when I changed my fuel filter, and the car runs, haha.
Old Jan 31, 2004 | 11:36 AM
aw1234dude's Avatar
Default Re: TECH - fuel filter question with diagram (King Tut33)
Yeah the the banjo fitting is actually channeled in the center if you look. So it will not matter what orientation the holes are on the bolt.
Old Jan 31, 2004 | 11:54 AM
Marauder's Avatar
Default Re: TECH - fuel filter question with diagram (aw1234dude)
Are you kidding! That hole needs to be lined up at exactly 42.35 degrees from the firewall....or else you will spray fuel all over the place!
Just kidding.....
it doesn't matter, just use new crush washers when installing the bolt.
Old Feb 1, 2004 | 09:42 AM
Philip's Avatar
Default Re: TECH - fuel filter question with diagram (Marauder)
thanks for the info guys!
Old Feb 1, 2004 | 09:54 AM
H22A EG6's Avatar
it dont matta yo good luck yo
MelJ
10
Mar 20, 2011 05:26 PM
Nicram
Feb 12, 2006 10:42 AM
95GS-R
Sep 5, 2002 03:47 PM
Mikey3000
May 16, 2002 11:59 AM
Ubermensch
Sep 24, 2001 07:50 AM
