i bled my coolant, and then tried to adjust the fast idle and problem occured :help:
Old Jan 31, 2004 | 10:43 AM
igo4bmx's Avatar
Default i bled my coolant, and then tried to adjust the fast idle and problem occured :help:
I bled my coolant which showed a couple bubbles to rise out of the lines, but not i have another issue.
it was stated to disconnect the IACV ( I have an auto IACV) to check the idle (which is high for my car at round 1k)
i reset the ecu to clear any CEL and then disconnected the IACV and my car would not hold a steady rpm. it would flicker up and down around 1500 rpm (about half a second between each up/down change)
is this normal? because i really can't check idle if its moving that fast
H22Honda98
Sep 5, 2007 05:51 PM
stupidwhitecat
Nov 14, 2006 07:37 AM
ILoveJDM.
Dec 25, 2005 11:34 AM
Ian in Oz
Jun 4, 2003 10:21 AM
LsTurbo91
Dec 18, 2001 12:23 AM
