arp lug studs
Old Jan 30, 2004 | 08:34 PM
skankz_em1's Avatar
Default arp lug studs
i just bought some arp extended lug studs and i really know how to install them
i was hoping someone can give me step by step instructions on how to install them
Old Jan 30, 2004 | 08:48 PM
Dan GSR's Avatar
Default Re: arp lug studs (coronaboylbc)
gotta take off the hub
press out the old studs
and press in the new ones
should change your wheel bearings at the same time
Old Jan 30, 2004 | 09:25 PM
B18bEK's Avatar
Default Re: arp lug studs (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">gotta take off the hub
should change your wheel bearings at the same time</TD></TR></TABLE>
yup .. you will have to take them to a shop to get them pressed out. changing the wheel bearings will just save hassle down the road i'm about to do the same install - just with skunk2 lugs.
Old Jan 31, 2004 | 05:26 AM
Dan GSR's Avatar
Default Re: arp lug studs (B18bEK)
i'd save yourself some headache
toss the skunks and get some arp
i've heard way too many ppl breaking the skunks
Old Jan 31, 2004 | 07:26 AM
b19coupe's Avatar
I second that. My Skunk 2 cams are great, but I had nothing but trouble with the Skunk2 wheel studs.
Old Jan 31, 2004 | 07:37 AM
b19coupe's Avatar
Default Re: arp lug studs (Manuel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manuel &raquo;</TD></TR><TR><TD CLASS="quote">Dont you have to tap wheld the back of the Stud</TD></TR></TABLE>
Tack welding the studs stops them from spinning, but does not help with them stripping because the metal is too soft.
Old Jan 31, 2004 | 08:01 AM
gsrswapdcivic's Avatar
you can use a slide hammer to remove the wheel hub then do the stud install. line up the hub on the axle and use air impact to tighten it back on. you have to get it tighter then when it was on their before so it will seat back on the bearing. just let it impact on till it wont move anymore I have done this many times and it works. this is how people at work do it(Honda dealership)
bmwe362006
Feb 23, 2009 06:21 PM
Quickridez_3
Sep 30, 2008 04:08 PM
crv-techu
Jun 10, 2008 01:51 AM
Jonathan_ED3
Apr 17, 2005 12:56 PM
dynamo
Sep 20, 2002 11:37 AM
