what would it take to get to 10 grand????
what would it take to get to 10 graand safley on a b16?????
also what would it take to get a b18c1 to 9500 safely????
thanx for ur help
thanx for ur help
I think HIGH REVIN motors are more dope then turbo kits these days.
To answer your question; It will take some engine work.
lol well ok i know engine work and i know like rods(crower is wut i would pick) and more compression(12:5.1or more i dont know wut would u all sugg.) which cams(juns,crower skunk2, toda???) would u all suggest and what type of valvetrain??
all motor newbie here ... so go easy on me. i'm reading and learning.
isn't a ctr motor just an itr motor destroked to 1.6 so it can spin higher? would destroking a gsr motor with a serious valvetrain allow me to see 10000? i'm kind of an rpm junkie ... as pointless as it is.
i tried searching about destroking but came up completly empty.
put in a new ecu with a 10k redline and rev the **** out of it.
id say you should do a bit more research before u start jumping into a project just to reach a 10k redline. its gonna cost a shitload of money to make a motor rev to 10k and be SOMEWHAT reliable.. (ur still gonna have a shitload of problems) all i can say is tuning is ur friend.
to rev 10k u will need
the block will need sleeves stock sleeves will not do it for 10k ($900)
aftermarket rods like eagel ($300) or crower ($500)
some forged pistons $500
banlance rotating assembly ($160)
the head will nead cams that will make power to 10 k like skunk2 stage 3's or something like that ($700)
springs and retaines($300-400)
There was just a post about this in the same section. Go check it out and download the video in the link. Pay close attention to the monster block girdle on the B-series engine in the video.
all you really need is good~reliable valvetrain, a well balanced botom end, good harmonic balancer, cam's designed to peek at that given power point, and a good induction system.
Mine did, but it gave away too much mid-range. Going from an ITR IM and 70mm TB to a Victor X IM with a 74mm TB. And I have to agree that most street motors don't make power that high, but it just sounds cool to say "my engine revs to 10 grand!"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote"><---------Never seen a street motor make power @ 10,000rpm.</TD></TR></TABLE>
ive only seen one race motor that makes power there. i havent seen a cam you can buy off the shelf make power at 10k. the highest peak ive seen is around 9 -9.2.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">Why would you want to rev to 10,000 if your not making power there?
The video I was referring to goes into a little detail on this matter. It's hard as hell to read the subtitles but you may want to check it out, I thought it was somewhat interesting.
BoostedSixthGen
Jun 11, 2003 03:45 AM
