Using Integra Solenoids with B18 88-91 Civic Swap
Im using the Purge Cut-off solenoid aswell as the Pressure Regulator Cut-off Solenoid.....My question is that the 88-91 DX civics only use the Purge Cut-off Valve.....so when I go to run the Pressure Regulator Cutoff solenoid....should I just use the OEM Connector....and run the Extra wire to the ECU.....there are 4 wire.....Green, Green/Yellow stripe, and 2 Blacks with Yellow Stripes....Obvious the Black with Yellow Stripes are grounds.....the the Green will connect to the green wire (Purge Cutoff Solenoid......now my big questioin is the left over Green/Yellow wire....(Pressure Regulator Cutoff) What ECU Pinout would it go to....and how or where should I connect it...I want to run the Integra Solenoids simply for emmisions....and Because I got rid of my crap.....whats everyones opinions..
Thanks
Brad
Thanks
Brad
InfamousRS
May 19, 2002 10:56 AM
