please look at my turbo and tell me how much hp i should get from it
Old Jan 30, 2004 | 06:51 PM
Prelude91siT's Avatar
Default please look at my turbo and tell me how much hp i should get from it
just as the topic says. its a t3/t4 turbonetics turbo, ceramic ball bearing section, stage v exhaust housing with a .63 and a 60-1hifi compressor . it was balanced to .2 g's at 62,000 rpms? here r some pics. if they dont work can somebody tell me how u post images from imagestation? here is the link to the album
http://www.imagestation.com/album/?id=4287837629
Old Jan 30, 2004 | 06:52 PM
Racerage1's Avatar
Default Re: please look at my turbo and tell me how much hp i should get from it (Prelude91siT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude91siT &raquo;</TD></TR><TR><TD CLASS="quote">just as the topic says. its a t3/t4 turbonetics turbo, ceramic ball bearing section, stage v exhaust housing with a .63 and a 60-1hifi compressor . it was balanced to .2 g's at 62,000 rpms? here r some pics. if they dont work can somebody tell me how u post images from imagestation? here is the link to the album
take orig.jpg off
Old Jan 30, 2004 | 06:54 PM
thanks alot
Old Jan 30, 2004 | 08:44 PM
TravSi's Avatar
Default Re: (Prelude91siT)
I just looked at it and it said to me 500hp! (sarcasim).....ok got that out of the way, What kind of setup are u runnin this on?? Whats your power level goals? How many girls you plan on picking up a night with that bad boy? With the additional info someone can better give you a probable guesstimate of what you can look forward to...cause in all seriousness different motors will see different results with that turbo.
Old Jan 31, 2004 | 08:48 AM
Default Re: (TravSi)
i will be runnin it on a fully built block by gem and a gude head. my turbo kit looks like this
84mm bore
Golden Eagle Mfg. "Goldzilla" sleeves ( holds 60 psi of boost
Eagle rods
ACL engine bearings
Arias Pistons
Bored and honed
Line bored
Sized rods
Balanced crank and rotating assembly
Polished and chamfered oil hole crank
Blueprinted and assembled bottom end
Old Jan 31, 2004 | 10:46 AM
Mr. Softee's Avatar
its a shame you are using a kit like that with sucha nice motor.
Old Jan 31, 2004 | 10:49 AM
4U2NV's Avatar
I hope you're ditching the FMU for a fuel management...
Old Jan 31, 2004 | 10:53 AM
oh no. i have a aem ems, aem wideband, gm 3bar boost seliniod, gm ait sensor and i'm getting 7 something cc injectors. the only thing i'm using from the kit is the a/w,downpipe w/ extrenal wastegate setup and manifold. this was the only bolt on kit ever produced for a 3rd gen prelude. so for now i have to take what i can get
Old Jan 31, 2004 | 01:42 PM
up
Old Jan 31, 2004 | 02:20 PM
EpDarks's Avatar
Is that an intercooler I see in that kit?
Get a frount mount for gods sake.
I'm impressed by your setup though. Nice motor, EMS... you should be able to make impressive numbers.
Old Jan 31, 2004 | 02:26 PM
93LSivic's Avatar
I hate these threads.
If I posted new tires should I ask how many miles I should get out of them?
Is that a t3/t4b? I see 7 blades on the compressor wheel.
Old Jan 31, 2004 | 04:17 PM
the only thing i know about the turbo is what i stated in the first post. thanks for all the replies even though they didnt help much
Old Jan 31, 2004 | 04:34 PM
B18bEK's Avatar
do you people not read the sticky threads
Old Jan 31, 2004 | 07:13 PM
i know i dont and wont
Old Feb 2, 2004 | 05:37 AM
should i be able to see atleast 400whp
CarbonCreations
Oct 19, 2005 03:38 PM
fjt
Aug 3, 2005 04:04 AM
Nandezuk
Jun 20, 2005 12:36 AM
B17aTrbo
May 5, 2004 07:49 AM
CLUNKER
Sep 4, 2003 12:25 PM
