Snapped some pics after GC install.
Front shot
Side shot. Waiting for springs to settle before adjusting them.
Picture of RS*R and the nasty bumper gouge.
DIY ram air intake. There's an intake tube on the front of the box that allows air passage if the tube was filled with water. 7 Months no problems. Box, tube, intake manifold is pretty cool to the touch at night after a grocery run. The 90 manifold helps too
Tube on bottom of car.
Engine Bay shot.
Sorry the pics are so big, no photo editing software to resize.
Dan
Engine Bay shot.
Dan
looks good, i like the intake tube, diy=
, screw the high prices these days for crap that doesnt make a difference (of course there is a limit to what you can do yourself, then you are forced to pay the high prices lol
Thanks guys. I will adjust them tonight. Gennessee is more close to UCSD. I used to live in that area when I used to go to UCSD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neonorific20 »</TD></TR><TR><TD CLASS="quote">nice rims!
Ben</TD></TR></TABLE>
Those are the best rims ever I got a set but mine’s look better. But you have to love 14’s.
The car rides so nice. Not bouncy at all, but I fear if I lower it a llittle more I will bounce a lot. But it rides tons tons better than stock. Notice how the steelies don't match? Hehe.. Thanks for the
Here are some pics of the actual install process.
https://honda-tech.com/zerothread?id=749517
Thanks guys. Keep the comments coming.
Dan
Here are some pics of the actual install process.https://honda-tech.com/zerothread?id=749517
Dan
nice choice i adjusted my Gc's right away on my DA
...i have them set at 2.5" Front and 2.0" rear with Illuminas ...and i have as much bounce as my friend with H&R race springs with the same shocks ...adjust them and let us know how you like the ride ...
p.s. what shocks are you running?
...i have them set at 2.5" Front and 2.0" rear with Illuminas ...and i have as much bounce as my friend with H&R race springs with the same shocks ...adjust them and let us know how you like the ride ...p.s. what shocks are you running?
...i think you should save and get some good shocks like the kyb agx's or the tokico illuminas ...of if you dont got the money kyb gr2's ....i drove around with stock shocks with bullshit coilovers before i got my Gc and illuminas and the 1st bump the shocks went bye bye ...drops on stock shocks
...or you will boucin around maybe not right away when it happens you will hate it ... i just dont want to see you break anything or whatever i know i wouldnt
na man ...i dont got a digi cam ...and my car anit in the best of shape ...its off the road and under construction
...i think a few of my friends my have pics of my car with the suspension in it ...its perfect though ...clean smooth JDM
p.s. you will be more than happy with the Illuminas
...p.s. you will be more than happy with the Illuminas
awww man I always love seeing pics of other DAs. Keeps me motivated. I can't wait to get my tax returns. Gotta save some dough for my girls engagement ring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cjames235 »</TD></TR><TR><TD CLASS="quote">looks good but you can go ahead and adjust the height. eibach springs arent supposed settle at all.</TD></TR></TABLE>
I don't know of any spring that will settle, except maybe those rice springs from Sprint or Arospeed...
If you're using the stock upper mounts, a simple ride around the block will settle the spring into the soft upper rubber. If you're using some sort of spherical bearing upper, then this isn't a problem at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDA9 »</TD></TR><TR><TD CLASS="quote">
If you're using the stock upper mounts, a simple ride around the block will settle the spring into the soft upper rubber. If you're using some sort of spherical bearing upper, then this isn't a problem at all.</TD></TR></TABLE>actually my friend has H&R race springs and koni's on his ITR and they settled ...first he had a one finger gap and now his tire is tucked just slightly ...and with my Gc's they settled a little bit ...its also the illusion that they settled because when the car is in the air or jacked up the suspension get streched out sorta and then goes back to its original position when its back on the ground after a second or two ...
