obd1 and obd2 Injectors: What's the difference?
Old Jan 30, 2004 | 05:09 PM
Civic Hx-T's Avatar
Default obd1 and obd2 Injectors: What's the difference?
CC's? What's the difference between the two or more accurately.. what's the difference between obd1 y5 injectors and obd1 z6 injectors?
I'm thinking I may need to find a set of obd1 z6 injectors for my swap if i'm using a p28 and all obd1 stuff right?
This is going to be info for the write-up on obd1 y5 swapping. Thanks.
Old Jan 30, 2004 | 10:53 PM
Civic Hx-T's Avatar
Default Re: obd1 and obd2 Injectors: What's the difference? (Civic Hx-T)
Bump for info.
Old Jan 30, 2004 | 11:39 PM
Civic Hx-T's Avatar
Bump again.
I just need a quick answer if anyone can tell me.
Old Jan 31, 2004 | 04:30 AM
T-RO's Avatar
Something I found on HT previously...
PS, sorry for the crappy size of that image, if you need it larger email me and I can send the file to you tro@mpinet.net
Old Jan 31, 2004 | 05:28 AM
Civic Hx-T's Avatar
Hmmm that's actually useful BUT it doesnt' have the d16y5's Injector size. That sucks.
Can anyonet ell me the y5's injector size or should I assume it's around 180-240.
I'd think it was at least 235.. not that far off from the y8's SINCE it's a newer motor but the "Efficiency" part... Vtec-E? Hmm.
Old Jan 31, 2004 | 08:01 AM
BatuKing's Avatar
Default Re: (Civic Hx-T)
This injector flow has been discussed many of times and all honda injectors are all 240CC..
as far as OBD-0, -1, -2 is concerned the difference is impedance. as the higher you get in OBD the higher the resitance is..
Old Jan 31, 2004 | 09:04 AM
RyanEJ8's Avatar
Default Re: (BatuKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing &raquo;</TD></TR><TR><TD CLASS="quote">This injector flow has been discussed many of times and all honda injectors are all 240CC..
as far as OBD-0, -1, -2 is concerned the difference is impedance. as the higher you get in OBD the higher the resitance is.. </TD></TR></TABLE>
Not "ALL" Honda injectors are 240cc. Just Civics and Integras. Also OBD I and II are the same resitance. The clips are different though, but can easily be swapped out.
Old Jan 31, 2004 | 09:09 AM
towns's Avatar
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">
PS, sorry for the crappy size of that image, if you need it larger email me and I can send the file to you tro@mpinet.net</TD></TR></TABLE>
If you use this link http://www.imagestation.com/pi...g.jpg and just click it, rather than post it as an image then it will be big again! I think!
Hardrath_R
Aug 7, 2012 11:35 AM
Hondatypr636
Aug 7, 2011 08:02 AM
swapshop
Dec 29, 2010 11:43 AM
