injector plugs. which side is ground wire?
Old Jan 30, 2004 | 04:31 PM
Origin's Avatar
Default injector plugs. which side is ground wire?
im doing the obd0 to obd1 conversion on a b16a into my crx and ive kinda got myself confused.
anyways im pretty sure the injector ground wire as it goes into the clip is on the right side. actually im almost positive, but since i don't have my motor right in front of me i can't seem to remember how the clip went on to the motor. the injector clip has a round cut out on either the front or the back depending on how you look at it. if im looking straight at the engine, like im working on it, should the cut out side be towards me or towards the back of the car? i removed 8 of these and you would think i would remember, but im just good like that. much thanks appreciated.
Old Jan 30, 2004 | 07:27 PM
boostn420's Avatar
Default Re: injector plugs. which side is ground wire? (Origin)
That cut is there so the plug will clear the injector on the far side, so it should be facing the firewall.
Performance Freaks EH
May 19, 2006 05:56 PM
Eluzion
Sep 11, 2004 11:36 PM
Origin
Jan 30, 2004 05:40 PM
