q about oil changes
Old Jan 30, 2004 | 03:05 PM
BeerBaron105's Avatar
Default q about oil changes
ummm i just bought my ek hatch and i want to do an oil change, i heard that hondas have crush gaskets that have to be used new with each oil change for the drain plug, i know for my talon i could just put my plug back in and i didnt need a crush washer or something
do i need it for the honda and are they only available at teh dealer?
Old Jan 30, 2004 | 03:07 PM
kKdARIAN's Avatar
Vice President/CEO
Default Re: q about oil changes (BeerBaron105)
i don't use a crush washer when i change my oil, jus screw the plug back in, mine doesn't leak.
Old Jan 30, 2004 | 03:08 PM
-Gambit-'s Avatar
Default Re: q about oil changes (kKdARIAN)
I havent changed mine yet, just change it when it starts looking bad.
Old Jan 30, 2004 | 03:24 PM
moondoggy's Avatar
yeh, the honda plug gasket crushes when u torque them. i just use a regular 14mm cooper instead..but they are pretty cheap anyways.
Old Jan 30, 2004 | 03:27 PM
JDMlyfestyle's Avatar
never used a washer on mine and havent had a leak yet
Old Jan 30, 2004 | 03:29 PM
976's Avatar
976
New User
Default Re: (JDMlifestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">never used a washer on mine and havent had a leak yet</TD></TR></TABLE>
You always want to use a washer otherwise your drain plug is more prone to getting stripped like you mom on a Saturday night.
Old Jan 30, 2004 | 03:33 PM
kKdARIAN's Avatar
Vice President/CEO
Default Re: (976)
guess i better start too.. ugh, my moms too old to be strippin'
learn somethin new every day... and get grossed out too.
Old Jan 30, 2004 | 03:47 PM
Riceburner247's Avatar
Default Re: (kKdARIAN)
I was told that Honda's used crush gaskets for the oil pan, not the drain plug.
I've been changing my own oil for 5 years, never once had a leak from the plug.
Old Jan 30, 2004 | 03:49 PM
mattssi's Avatar
Never used one here, never had a problem! Wait? are we talking about condoms?
Old Jan 30, 2004 | 04:09 PM
Jer's Avatar
Jer
Default Re: (mattssi)
if you buy honda oem filters(highly suggested) they will most of the time just give the washer to you for free. if not they are only like fifteen cents.
Old Jan 30, 2004 | 04:12 PM
degooser's Avatar
Default Re: (GERM)
for all you lazy asses just flip the washer or if you really want to get nitty gritty just sand it down...f it better than not having one..
Old Jan 30, 2004 | 06:42 PM
so can i just keep reusing the same one, it seems like a pain to drive 25 min just for a 15 cent piece
Old Jan 30, 2004 | 08:17 PM
GreenBean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeerBaron105 &raquo;</TD></TR><TR><TD CLASS="quote">ummm i just bought my ek hatch and i want to do an oil change, i heard that hondas have crush gaskets that have to be used new with each oil change for the drain plug, i know for my talon i could just put my plug back in and i didnt need a crush washer or something
do i need it for the honda and are they only available at teh dealer?</TD></TR></TABLE>
Per Honda instructions, any aluminum crush washer needs to be replaced....Its not all about the fluid leaking but also the drain plug staying put....the more you re-use them the bigger chance they could crack and more likely you'll be over-tightening the drain plug...And on the newer engines that means replacing an aluminum oil pan. Its .36 for piece of mind...
Old Jan 31, 2004 | 03:31 AM
Default Re: q about oil changes (GreenBean)
are these available at any parts store or are they dealer item only?
Old Jan 31, 2004 | 06:38 AM
Yokohama's Avatar
Default Re: (Dimi)
I have used the same washer that came with the car until I bought a Honda filter and it came with a new washer...doesnt make a diff I have noticed...as long as you tighten it correctly it will be fine...
Old Jan 31, 2004 | 06:43 AM
Debaser's Avatar
Default Re: (BeerBaron105)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeerBaron105 &raquo;</TD></TR><TR><TD CLASS="quote">so can i just keep reusing the same one, it seems like a pain to drive 25 min just for a 15 cent piece</TD></TR></TABLE>
For the cost, just replace it. Instead of driving 25 minutes for a 15 cent piece, go crazy and drive 25 minutes and get a dollars worth. Better yet, go absolutely nuts and get 2 or 3 dollars worth.
If you're changing your own oil, it makes sense to buy in bulk, cuz yer gonna need the stuff anyway. Case or 3 of oil, case of filters, a jar full of washers etc.
You won't have to re-up everytime you need to change your oil.
I'm currently experimenting with a product called "Sure Drain" by Fram. You replace your stock DP with theirs, which has an actuator valve in it. When you want to change your oil, you screw on a short length of hose that comes with the kit, it opens the valve and out comes your old oil into the jug you've supplied. So far I love it; it's quicker and there are no tools needed.
It's 12 bucks at Walmart and the one for a D16 oil pan is the SD-2, since there are 5 different ones, I believe. Just make sure you run the car first b/c hot oil is far less viscous than cold oil and the drain time will be reduced significantly.
Old Jan 31, 2004 | 06:56 AM
Debaser's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeerBaron105 &raquo;</TD></TR><TR><TD CLASS="quote">are these available at any parts store or are they dealer item only?</TD></TR></TABLE>
You should be able to get them anywhere. I paid a dollar for a bag of 20 at Auto Boyz or Pep Zone, which I think was the wrong price, but I didn't argue.
Old Jan 31, 2004 | 07:18 AM
b16si's Avatar
Never done that before. Its prolly just something shops tell you to do to sqeeze and few more bucks out of you.
Old Jan 31, 2004 | 07:20 AM
ej1 coop's Avatar
Default Re: q about oil changes (b16si)
dealerships tell you to use them so they can make extra money when i was at honda i never told the people that bought oil filters that they needed you should be fine with out one
Old Jan 31, 2004 | 08:08 AM
boosted1993's Avatar
Default Re: q about oil changes (ej1 coop)
yeah it's just a regular washer anyways so you don't overtighten the drain plug and strip the pan out. spec 32 foot lb's
Old Jan 31, 2004 | 08:17 AM
SLeePeR012's Avatar
Default Re: q about oil changes (boosted1993)
ITS FREE FROM HONDA IF YOU PURCHASE AN OIL FILTER........
ahloung
14
Mar 14, 2006 10:29 AM
t0ekn3e
19
Mar 22, 2004 12:16 PM
shortyz
12
Dec 18, 2002 02:55 PM
justinCO
Oct 7, 2002 02:37 PM
Fooman
Sep 18, 2001 07:29 PM
