I need help with exhaust bolts
Old Jan 30, 2004 | 02:13 PM
slowride2's Avatar
Default I need help with exhaust bolts
I was taking my exhaust loose from the manifold or where the two pipes connect the exhaust to change oil pan gasket. Upon loosening the nuts, the nuts got tighter the further I turn. One of the nuts stripped and I left the other two alone, but they have been broken loose.
Question is, how do I get these 3 nuts off. After they broke loose they seemed to tighten back up. Thanks.
Old Jan 30, 2004 | 06:27 PM
Kendall's Avatar
You may have to drill the broken one out. Did you use any sort of penetrating lubricant when you tried to remove it?
Old Jan 30, 2004 | 06:49 PM
gloryhog's Avatar
Default Re: I need help with exhaust bolts (slowride2)
get a grinder or dremel and cut that bastard off then put new studs in it and use anti-seeze on them !
Old Jan 30, 2004 | 07:13 PM
boostn420's Avatar
Default Re: I need help with exhaust bolts (gloryhog)
Just turn the others until they break off. Then hammer out the broken studs and replace them or use nuts and bolts.
hulsey
Oct 24, 2012 02:34 PM
eg6REDmilano20
Mar 25, 2009 02:26 PM
LaOstha
Sep 1, 2006 02:32 PM
jweezy225
Jun 19, 2004 06:33 AM
au-gsr
Nov 13, 2002 04:37 PM
