piston to valve clearance question.....
i am getting zero feedback in the tech forum so i brought it here,alrighty, heres the situation, i have a spare ls block just sitting in my garage that needs to be rebuilt, but i dont want to just build it back to stock id like to put some different compression pistons in the motor but still use the ls rods to keep my costs down cause im trying to focus on getting my own place to live and the **** that goes with your own home, heres my question, will i be able to run a high compression piston, say 11:1 or so using an ls head without having any piston to valve problems, will the combustion chamber allow it or is it to flat of a surface area to allow the higher compression piston, could i use a piston out of a civic type r without any problems if i had to?, id like to run either 11 or 12:1 compression on the street to give the motor a little more pep, just need some tech answers, thanks in advance to all who can help me out........
You should be fine. What cams you have will make a difference. High lift cams could pose problems but if you're using stock cams, you should be great. I have Crower Stage 3 cams and CTR pistons in my Integra and it has no valve clearance problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegmech »</TD></TR><TR><TD CLASS="quote">stock ls with turbo kit,a little time on the dyno, 261 hp, 228ft lbs torque at 5600 rpm on 13 psi= FUN....????? 11:1 or 12:1 seems a bit high for that boost level.</TD></TR></TABLE>
i wont be boosting this motor........those numbers are on my current setup, actually there not,i sold the turbo kit a week ago so i should prolly change that....but thanks teg builder.....
noracelimit
Mar 30, 2009 12:21 PM
Jay_Sensing
Jan 14, 2007 07:20 PM
