Differences between engine series?
Old Jan 30, 2004 | 11:09 AM
malix's Avatar
Pork is NOT a verb!
Default Differences between engine series?
Im new to Hondas, and im just wondering what the differences are between the engine series? For example, what sets the K series apart from B series engines? I was hoping you guys could enlighten me, or point me to a website or something.
Old Jan 30, 2004 | 11:42 AM
Kendall's Avatar
You're going to have to do a lot of research. There isn't just a couple of things that make them different, every aspect of the engines are different. The K series uses a more advanced VTEC system, is mounted backwards from the B series, has different internal dimensions, different cam profiles, different flow rates for the head, different everything. Like I said earlier, do some research on both engine series and then compare notes.
Old Jan 30, 2004 | 12:46 PM
8200RPM's Avatar
local hippie
Default Re: Differences between engine series? (toxin813)
http://www.jdmuniverse.com/for...0Info
voila! hope that helps
Old Jan 30, 2004 | 12:54 PM
malix's Avatar
Pork is NOT a verb!
Default Re: Differences between engine series? (8200RPM)
Thanks!
Old Jan 30, 2004 | 05:28 PM
Sliced Beard's Avatar
they have different names
Old Jan 30, 2004 | 05:35 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8200RPM &raquo;</TD></TR><TR><TD CLASS="quote">http://www.jdmuniverse.com/for...0Info
voila! hope that helps</TD></TR></TABLE>
I noticed some errors on that site, do some additional research to get everything square.
Old Jan 30, 2004 | 09:21 PM
8200RPM's Avatar
local hippie
Default Re: Differences between engine series? (Kendall)
yes, there are errors here and there. just like any other site will most likely have. but its a good start and covers alot.
jseaton357
55
Oct 15, 2017 02:32 AM
soloDC
Jan 7, 2015 06:29 AM
turbohenry
Mar 29, 2008 05:18 PM
mrnice1058
Dec 10, 2004 05:53 AM
