High RPM missfire
Old Jan 30, 2004 | 10:34 AM
Griffin@Camtech's Avatar
Default High RPM missfire
Hey guys,
I am wondering if someone could help shead some light on this.
I have a LS/vtec with a B18c head. the thing runs like a dream from idle to about 6000RPM but from 6000 to 8000 there is a very slight missfire. Not bad but it is there. the ignition is stock. The air fuel mixture is good. the motor is run off a chipped p28 but i know thats not the problem I swapped it with another p28 and it did the same thing. Anyone have any ideas?
Thanks
Old Jan 30, 2004 | 11:40 AM
lsvtec101's Avatar
Default Re: High RPM missfire (EK2NR)
check the plugs or the gaps in the plugs? might have one out of gap.. maybe the wires also that will cause a missfire.
Old Jan 30, 2004 | 11:42 AM
Rocket's Avatar
Default Re: High RPM missfire (aemcivic_02917)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aemcivic_02917 &raquo;</TD></TR><TR><TD CLASS="quote">check the plugs or the gaps in the plugs? might have one out of gap.. maybe the wires also that will cause a missfire.</TD></TR></TABLE>
Yep yep. 0.035 - 0.038" gap is good for street all motor.
sicksquishey37
Jul 10, 2008 01:53 PM
Dohc 4door Rye
Apr 22, 2006 11:21 AM
IH82LOSE
15
May 30, 2004 06:33 AM
Griffin@Camtech
Jan 30, 2004 03:05 PM
integranator
Jan 16, 2004 08:03 AM
