Swaybars
Old Jan 30, 2004 | 09:26 AM
bboylito's Avatar
Default Swaybars
Where can i get "poormans" swaybars for a eg hatch? what are the good brands or sizes, i often see 13mm or 22mm whats the difference? Thanks
Old Jan 30, 2004 | 09:28 AM
bboylito's Avatar
Default Re: Swaybars (bboylito)
also where do they connect? can i have a rear lower tie bar and also have a rear way? SORRY FOR THE NOOBNESS
Old Jan 30, 2004 | 09:38 AM
FrostySol's Avatar
Ok, first, search, your answers are out there. And second, if you plan on gettting any performance from your parts, don't go "poorman". If it's just for show that's one thing, but for anything else just save your money and get something better.
Old Jan 30, 2004 | 09:44 AM
ProEater's Avatar
Default Re: Swaybars (FrostySol)
when in doubt................
Old Jan 30, 2004 | 09:51 AM
bboylito's Avatar
well i never go poormans unless its things that dont matter for instance a pipe with a filter on the end, or a metal bar that stiffens the chassis, i guess with a swaybar it matters so thanks for letting me know but does anyone have any places where they go for pretty cheap, i checked ebay and =no good
Old Jan 30, 2004 | 09:52 AM
nwdave's Avatar
Default Re: (bboylito)
ITR sway bars are good and fairly cheap.
Old Jan 30, 2004 | 09:57 AM
bboylito's Avatar
sweet thanks delsolguy, do they bolt right up?
know of any places to get em
Old Jan 30, 2004 | 10:00 AM
Mr. Samurai's Avatar
Default Re: (delsolguy)
Most people who do have a poormans sway setup usually end up with a ripped subframe. its up to you but I would say go with a sway bar thats been proven, this doesnt necessarily mean to go with a name brand. How the make the sway is also important, is it hollow? what is the bar made of? how strong is it? how much does it weigh? what comes with it? a hollow 22mm bar could have the same effects as a solid 13mm, and yes some sway bar kits do have tie bar.
Old Jan 30, 2004 | 10:19 AM
kommon_sense's Avatar
Default Re: (L33T)
IIRC, the sways from a GSR should fit on your eg. Also, rear GSR sway isn't as big as ITR rear sway so shouldn't be any issues with ripped subframe. People typically go overkill on swaybars and think that bigger is better. You've got to match the bars to the rest of your suspension to get the right balance...
Old Jan 30, 2004 | 10:48 AM
^R@m!r0_(M)
Guest
Posts: n/a
Default Re: (kommon_sense)
if you click on search you can type in swaybar and if you want a new one pick sponsers forum or there are some really good deals on quality parts in the classifieds
PS noobies are silly
Old Jan 30, 2004 | 10:59 AM
SOHC_MShue's Avatar
if you go with the 22mm itr swaybar make sure you get the beaks kit to prevent subframe tearing. Even then it still isn't 100% bulletproof though . A couple of people on this site with the beaks and itr bar setup have ended up with torn subframes.
Old Jan 30, 2004 | 11:00 AM
POE's Avatar
POE
man thats crazy i wouldnt even mess with that then, can anyone suggest any good rear strut bars?
Old Jan 30, 2004 | 11:02 AM
JurakS's Avatar
Default Re: (L33T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L33T &raquo;</TD></TR><TR><TD CLASS="quote">Most people who do have a poormans sway setup usually end up with a ripped subframe. its up to you but I would say go with a sway bar thats been proven, this doesnt necessarily mean to go with a name brand. How the make the sway is also important, is it hollow? what is the bar made of? how strong is it? how much does it weigh? what comes with it? a hollow 22mm bar could have the same effects as a solid 13mm, and yes some sway bar kits do have tie bar. </TD></TR></TABLE>
wait, does it really matter on the sway bar if the subframe rips? isn't it the subframe that is weak? i mean alot of people's subframes have ripped and they have a good quality sway bar...i think you just need reinforcement ,no?
Default Re: (Vtecin94dx)
itr/skunk/benen/etc....
Old Jan 30, 2004 | 11:07 AM
stevecockrill's Avatar
Default Re: (Juraks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Juraks &raquo;</TD></TR><TR><TD CLASS="quote">
wait, does it really matter on the sway bar if the subframe rips? isn't it the subframe that is weak? i mean alot of people's subframes have ripped and they have a good quality sway bar...i think you just need reinforcement ,no?</TD></TR></TABLE>
IMO its the fact that people will often run the stiffer sway bar (whatever brand it may be) with stock or innappropriate stiffness suspension. If the suspension travel is limited by the use of stiffer shocks and springs, then the addition or use of a thicker sway bar will not put so much stress on the subframe. I've had the ITR bar on with Progress coilovers and a Beaks kit for 3 years now, and have had no problems whatsoever. A lot of fun, but no problems.
My 0.02
Steve
Old Jan 30, 2004 | 11:11 AM
92b16vx's Avatar
IMO, if you are looking for an inexpensive set up, just use stock Del Sol vtec ones.
sleepyEK's Avatar
man, i've always used the suspension techniques set ups. they work great and have never had any problems with torn subframes. they aren't that expensive either, especially for the eg.
Old Jan 30, 2004 | 11:14 AM
JurakS's Avatar
Default Re: (stevecockrill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevecockrill &raquo;</TD></TR><TR><TD CLASS="quote">
My 0.02
Steve</TD></TR></TABLE>
cause i know my friend with a '00 si and apexi WS damper kit..put on a mugen sway bar and just ripped his subframe up..but then he put that kit..i don't know the name..but it's a reinforcement kit
Old Jan 30, 2004 | 11:18 AM
E-Rok's Avatar
EPIC TUNING
ITR sways can be had for $75 each
Old Jan 30, 2004 | 11:20 AM
POE's Avatar
POE
will someone post a pic of one so i can see what they look like?
Old Jan 30, 2004 | 11:21 AM
1C9R9X3's Avatar
i would segest just getting the gsr sways, they bolt right in and you can find them on here for very reasonable prices. if not there is always the junk yard. i got my sways from H-T.
Old Jan 30, 2004 | 11:42 AM
Bull's Avatar
Check here for a very competent, reliable and fairly inexpensive set-up: http://www.beaksproducts.com/products.html
Old Jan 30, 2004 | 12:03 PM
Tad's Avatar
Tad
Default Re: Swaybars (Bull)
I dont trust the beaks kit imo,
unles your running really stiff springs to go along with it
(which actually is the real reason subframes tear,
if your springs are too soft then the bar does all the work and
rips through your subframe).
a rear tiebar like the comptech one is perfect protection,
and I dont really see a subframe tearing with it... I mean.. of course
theres always that slim chance, but i've never heard of it happening and doubt
I ever will.
Old Jan 30, 2004 | 02:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecin94dx &raquo;</TD></TR><TR><TD CLASS="quote">will someone post a pic of one so i can see what they look like?</TD></TR></TABLE>
ITR rear sway with Nuespeed rear LCA tie bars. Beaks SRKII.....
Steve
1sikhatch
Suspension & Brakes
Aug 22, 2010 08:12 PM
gitrdone
Honda Civic (2001 - 2005)
27
Jul 14, 2006 06:16 AM
Rayz_Si
17
Mar 24, 2006 02:23 PM
b18vtek
Jan 10, 2005 09:26 PM
beakert216
Aug 15, 2002 12:47 AM
