b16b cams in ITR
Old Jan 30, 2004 | 07:41 AM
an2ny888's Avatar
Default b16b cams in ITR
has anybody done this swap? my JDM ITR engine came with this, and its really noisy. i want to adjust the valves but dont know what specs to use. can someone help please?
Old Jan 30, 2004 | 07:43 AM
RTW DC2R's Avatar
Default Re: b16b cams in ITR (an2ny888)
clearance should be the same, no matter what cams you have installed, no?
Old Jan 30, 2004 | 08:28 AM
StudioJDM's Avatar
what year is your R motor? The exhaust cam on both are identical and in 00-01 i believe (might have been earlier...) Type R's used the exact same intake cam as the CTR. If your motor is a pre 00-01 and has the ctr intake cam in it, just get the valve adjustment specs on a newer R and you are set.
Old Jan 30, 2004 | 11:25 AM
an2ny888's Avatar
Default Re: b16b cams in ITR (ZigenGSR)
that's what i don't understand. the engine is a july 2000 year model, so theoretically the stock cams should already be indentical to the CTR ones. if so why would the previous owner have bothered to swap the cams?
Old Jan 30, 2004 | 11:35 AM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">that's what i don't understand. the engine is a july 2000 year model, so theoretically the stock cams should already be indentical to the CTR ones. if so why would the previous owner have bothered to swap the cams? </TD></TR></TABLE>
Because he was uneducated and didn't know. Just use the stock specs and you should be fine.
gsrintegra18
Oct 2, 2006 03:50 PM
Quiks66
Oct 31, 2003 05:40 PM
thrty8street
Oct 27, 2003 07:44 AM
AllMoToRB18c
Oct 26, 2003 02:33 PM
JDMvtecDRAGSTA
Jul 20, 2002 01:20 PM
