How Do You Measure These?
Old Jan 29, 2004 | 08:57 PM
Full Race A6's Avatar
Default How Do You Measure These?
But I really want to know how you guys tell how you figure out all the things you guys seem to know about your boxes.
Like how many cubic feet it has (I just forgot the formula I know its easy) and how you determine what your port hz is set to and things like that.
Never really checked on my box.
Thanks
Old Jan 29, 2004 | 10:06 PM
Spider Man's Avatar
Default Re: How Do You Measure These? (PIMPIN)
(Length X Width X Height)/1728 = cubic ft
Old Jan 29, 2004 | 10:41 PM
Default Re: How Do You Measure These? (Spider Man)
Dam I couldnt figure out what I was doing wrong when i was getting such a high as number. Had no idea about the 1728. Thanks
Now how can I tell what my port is tuned to?
Old Jan 30, 2004 | 04:22 AM
HondaDriver4Life's Avatar
How's your Algebra? The tuning frequency is a function of the port diameter, port length and the volume of the box.
To get the tuning frequency, you'll need the following info - all in inches:
R - radius of port
Lv - length of port
Vb - volume of box (in cubic inches)
Next, calculate the following:
1. 14630000xRsquared)/Lv
2. 1.463xR
Add answer 1 to answer 2 and divide the total by the box volume. Now take the square root of your answer and that should be your tuning frequency.
If you want an easier method, use the port calculator from this link and just plug in numbers until you find the answer.
http://www.the12volt.com/caraudio/boxcalcs.asp#por
Old Jan 30, 2004 | 06:30 AM
Default Re: How Do You Measure These? (HondaDriver4Life)
Thats a perfect answer but I think its gonna be hard to do that myself.
What exactly is the radius of the port? There square
Old Jan 30, 2004 | 06:43 AM
The radius is half the diameter. To get the diameter, measure across the port opening from one side to another. It might be a little tricky if the port has a flared end.
Is this a prefab box or a custom made piece? Are looking to build one for a specific subwoofer? What sub do you have?
Red-Rag-B18
Audio / Security / Video
May 30, 2010 05:51 PM
newrising
Mar 11, 2008 11:33 AM
Optiks.
10
May 26, 2005 01:40 PM
initialvtec
10
Apr 27, 2004 01:35 PM
schwinn
Jun 19, 2002 10:47 PM
