sunroof opens, with my help
Old Jan 29, 2004 | 08:07 PM
n3v3tz's Avatar
Default sunroof opens, with my help
hey guys like i said in other posts, i just got my 94 civic today....when i go to open the sunroof i have to hold the button down but i gotta push the sunroof to get it to pop up, after that it works fine...any ideas on what i need to do to fix it? thanks
Old Jan 29, 2004 | 08:10 PM
NonovUrbizniz's Avatar
Loved
Default Re: sunroof opens, with my help (n3v3tz)
Spray the rubber seal that goes around the glass with silicone spray lube (NOT ADHESIVE) also grease the tracks a little (NOT WITH THE SILICONE SPRAY)... use some of that yellowish clear grease... then run it back and forth a couple times... you may need to re-spray the seal just make sure it's good and even... I'd probobly spray the lube onto a rag and then rub the rubber real good...
Also clean the mating surface of the roof (the part that's un-exposed when the sunroof is closed) and wax it...
dgreen78
Mar 9, 2012 03:40 AM
cilvia
26
Feb 7, 2006 06:48 PM
FredoSP
Jan 14, 2005 04:27 PM
PHATACCORD94
Nov 7, 2002 12:20 PM
TsunamiZC
Sep 10, 2002 11:11 AM
