How are engine mounts removed?
jack your car up put it up on jack stands and then place a jack on a STRONG suitable place on the motor/tranny. DO NOT DO YOU oil pan. and if your doing the front two tourq mounts you dont need to do this they are"tq" mounts not weight bering mounts. and from reading what you just wrote about filling moutns i think these are the ones your talking about
and a note. if you're doing the rear mount. ITS A FUCKN BITCH TO DO WITH THE MOTOR IN. when i first did my motor swap i had the mount on the car and not on the motor ya fuckn **** was hard as a mother ******. the second time i pulled my motor out and replaced the rear mount i atached all the bolts to the motor and then just had to do the one onto the car this is a MUCH BETTER method IMO
