HELP!!! I DROP THE LOCKNUT DOWN THE PORTS!
Old Jan 29, 2004 | 04:05 PM
tuan...'s Avatar
Default HELP!!! I DROP THE LOCKNUT DOWN THE PORTS!
well i was backing out the locknuts to relieve the pressure off my rocker arms and i guess i backed it out too far. wen i took the socket off the locknut fell out and went into one of those ports on the side. im assuming it goes straight into the block but im not positive where. does it drop the coolant things on the side?? im soo pissed off1!!! wat should i do??
Old Jan 29, 2004 | 04:11 PM
i3luemrld's Avatar
Default Re: HELP!!! I DROP THE LOCKNUT DOWN THE PORTS! (h22a4_dc2)
well there are a few tools one is a telescopic arm that has a magnetic tip u can stickdown the prt the other is a flexible snake like tool forgot the name but it has a grapler on the other end for u to grab stuff u dropped in small unreachable spots
Old Jan 29, 2004 | 04:20 PM
satan_srv's Avatar
Default Re: HELP!!! I DROP THE LOCKNUT DOWN THE PORTS! (i3luemrld)
The telescopic magnetic thing sounds like your best bet
Old Jan 29, 2004 | 04:32 PM
tuan...'s Avatar
hmm whre can i get one of those??
Old Jan 29, 2004 | 04:35 PM
im_poor's Avatar
Default Re: (h22a4_dc2)
harbor freight
Old Jan 29, 2004 | 04:40 PM
tuan...'s Avatar
wtf is harbor freight??
Old Jan 29, 2004 | 04:41 PM
tuan...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i3luemrld &raquo;</TD></TR><TR><TD CLASS="quote">well there are a few tools one is a telescopic arm that has a magnetic tip u can stickdown the prt the other is a flexible snake like tool forgot the name but it has a grapler on the other end for u to grab stuff u dropped in small unreachable spots</TD></TR></TABLE>
i cant even see it, but i know where it dropped...
im_poor's Avatar
http://www.harborfreight.com/
or any auto parts store should have something similar
Old Jan 29, 2004 | 04:46 PM
tuan...'s Avatar
nvm, that site's search function sucks
Old Jan 29, 2004 | 04:48 PM
Revi's Avatar
Just go to any autozone or pepboys, the all have em. They look like a thin pen but extend to like a foot or something.
Old Jan 29, 2004 | 04:50 PM
tuan...'s Avatar
alrite ill go get one tomorrow, hopefully it comes out..thanks for the help guys
Old Jan 29, 2004 | 06:09 PM
H22A EG6's Avatar
damn sux
it will be ok guy
Old Jan 29, 2004 | 06:17 PM
ludeboy555's Avatar
Default Re: (H22A EG6)
may the force be with you
Old Jan 29, 2004 | 07:06 PM
tuan...'s Avatar
lol thanks. hopefully it isnt that bad... like involving taking the head back off....dammit im so careless
Old Jan 29, 2004 | 07:12 PM
IhAvEaLuDe's Avatar
sounds like something that would happen to only me.. welcome to the club.
Old Jan 29, 2004 | 07:17 PM
tuan...'s Avatar
heh i think i have a bigger list of f**k ups then you do...
Old Jan 29, 2004 | 07:24 PM
IhAvEaLuDe's Avatar
well... i dunno you, and u dunno me, but i bet i can beat if not come close to what u've been through.... lets just say, engine rebuild.. yea i was sent 3 diff **** h22 blocks... and that's just to start.
Old Jan 29, 2004 | 08:54 PM
p3s7's Avatar
sounds to me if you've never heard of a telescoping magnet, then maybe you shouldnt be messing around with the head on your car? just an idea
Old Jan 29, 2004 | 11:11 PM
preluda92's Avatar
Default Re: (p3s7)
Don't worry I have experience with the same problem. Only mine came off at the track, at the top of third . Just drop the oil pan, pull out the nut and you'll be fine! I reused the nut. Yes, it can and did fall all the way down to the oil pan.
Old Jan 29, 2004 | 11:36 PM
MR5sARECOOL's Avatar
Default Re: (preluda92)
yeah, its probly in the pan like^^^ said
Old Jan 30, 2004 | 05:14 AM
tuan...'s Avatar
well hopefully its not.. it sounded like it drop on top of the block
Old Jan 30, 2004 | 06:50 AM
david_rg79's Avatar
man...that sucks
when i was going to adjust the valves on my buddys h22.....he pulled the valve cover and a washer fell down in there....and we could not find a small enough magnet....however i was able to grab it out of that "port" with some long needle nose pliers....i wish you the best of luck
Cheers
David
Old Jan 30, 2004 | 09:34 AM
tuan...'s Avatar
thanks alot guys, im going to work now.. illl stop at autozone on the way home and try it out. what are the chances of it being in my oil pan?? hopefully it jus fell and sat on top of the block...
Old Jan 30, 2004 | 11:19 AM
SKDRCR's Avatar
i don't see how it could be in your oil pan,
if it fell in the ports, wouldn't it drop down in the cylinder
and be sitting on top of the piston?
Old Jan 30, 2004 | 12:58 PM
luder94-ChrisA's Avatar
Default Re: (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">i don't see how it could be in your oil pan,
and be sitting on top of the piston?</TD></TR></TABLE>
Ports are either for oil or coolant (most likely oil since we're all the way on top of the head). Since we don't intentionally mix oil or coolant with the fuel/air in the combustion chamber, there should be no way that the nut would end up on top of the piston if it fell in the ports...
