HID Kit Grounding points??
I purchased a used HID KIT which has no booklet so i dont know where to ground it to... so far i grounded it to the bolts that holds the headlight in.... but i know there are "better" points... should i just put em straight to the battery?? any help would be appreciated. thanks.
wrong forum probably,
Just look for a screw/bolt that is really close by. On one side you could use the same ground that the engine is grounded by. the other side should have plenty to choose from. Its not that hard!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill_take_one »</TD></TR><TR><TD CLASS="quote">wrong forum probably,
well my drivers side, i have abs, so the rooms minimized there,, on my pass. side, my switches to my system are all there, but would a better grounding point make a difference in the output of the lights?
blkgsr03
Sep 10, 2003 09:45 PM
