Greddy turbo timer on a 97 Civic EX. What color wires go to where...?
I recently finished my turbo project but the only thing that I need is to hook up a Greddy turbo timer. I am having a problem with the blue and green wire. I had the red wire from the timer connected to a 12Volts constant power and I have 12 volts coming out from both the blue and green wire even when the timer is off. I beleive that it is broken(got it from ebay, from Japan).IS IT? But I might be wrong. What wire color from the ignition switch is the blue and green suppose to go? Also, does honda ignitions have 1 or 2 ignition ON? Any help would be appreciated.Thanks.
i belive honda has 2 ing on wires. look at the back of the ignition switch where all the wires are soldered on. each wire is labled on the body of the switch.
SRT-WHORE
May 13, 2005 05:01 AM
