crank plugs needed after rebuild?
I just got my b18a back from the machine shop (unassembled) and was told to be sure to install the crank plugs before putting the bottom end back together. Anyone know what they're referring to?
The person I talked to at the shop seemed to think that there were some oil plugs in the crank, similar to pipe plugs, that needed to be installed...
The way the machine shop guy put it made it sound like something on the crank itself, but that doesn't make sense to me. Are there extra plugged oil holes that get opened when the crank is ground? The main caps are bolted to the block. Maybe freeze plugs...
Thanks for the input guys. Any other thoughts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">
Because b series dont have freeze plugs..they have those big *** bolts</TD></TR></TABLE>
That's what I meant, didn't know what the hell to call them.
The oil holes are drilled all the way through and then pluged on the end. Usually there is a little ball bearing and the crank is staked in three places around it so they dont fall out. If those are out, an Im not sure why a machine shop would remove them, then I would say tapping and plugging those hole is the best thing to do.
Not many people go thru the work of removing these,but it is the right thing to do.You can't completely clean the passages with out removing them and grit can hide in the dead end pocket.As the engine runs this crap can get free and ruin the crank and bearings.With these plugs removed you can brush out these passages and then replug them.
Glenn
Glenn
why would you replug them with the same things? you tap the holes and put a removable plug in so you can do this with ease each rebuild instead of doing it the hard way. This is not something that most any people do but do it right or don't do it at all.
it sounds like the machine shop is doing things the right way. i will take a look today and see what i can do about plugging the holes. are these plugs specialty items, or hardware store pieces? i imagine they're pretty small.
b20vtech
26
Jul 28, 2008 12:33 PM
zCivic
Nov 15, 2004 05:17 PM
