OEM pistons and comp. ratios Q's
Old Oct 4, 2001 | 04:07 PM
Padawan's Avatar
Darth ModerVader
Default OEM pistons and comp. ratios Q's
I seem to remember a while back that someone suggested using B16 pistons (not the CTR slugs) in their B18B/hybrid motor to achieve a comp. ratio higher than the ITR pistons but lower than the CTR ones. I found some numbers and did some quick math. I came up with a comp. of around 11.3:1 for B16 pistons in an ITR. Is that about right? With all the Si's doing engine build-ups I would think these would be easy to find too. The only problem I can think of might be some incompatibily with the ITR rods since I know CTR pistons will basically drop in to an ITR, but when installing them in a B16A the rods need to be modified.
mugen12_35sec
Apr 13, 2006 04:20 AM
greasemonkeys
Jan 7, 2005 06:41 PM
hybrid_vtec
12
Aug 11, 2004 12:49 PM
sikcrx80
Aug 9, 2003 07:46 AM
DJ KrunchyKracker
May 8, 2002 09:01 PM
