Built Transmission or Built Motor
Old Jan 29, 2004 | 11:38 AM
Brett's Avatar
Default Built Transmission or Built Motor
Given the option of mildly building your motor or mildly building your tranny which do you think would be most beneficial? I'm not talking just 1/4 mi. Overall street driving performance. I've been told that it's a lot more fun with a built tranny. BTW I don't exactly know what you would do to build a tranny so if anyone wants to add please do so.
Old Jan 29, 2004 | 12:04 PM
dmotoguy's Avatar
Default Re: Built Transmission or Built Motor (Brett)
if your talking about leaving one stock and modding the other.. motor
Old Jan 29, 2004 | 12:23 PM
acy76's Avatar
I believe most people modify their transmissions to change the gear ratios or to add a limited-slip differential. Some companies such as ATS advertise stronger gears, but the stock parts ought to be plenty strong for any 'mild' engine build (and beyond..).
Old Jan 30, 2004 | 09:33 AM
PupaScoopa's Avatar
Default Re: Built Transmission or Built Motor (acy76)
Sometimes, in various racing sanctions, you can only modify the motor so much. In that case, if you can modify the transmission legally then go for it.
Old Jan 30, 2004 | 10:08 AM
LX4CYL's Avatar
I'd have more fun putting in a Quaife LSD than spending the same amount (or more) on bolt ons...
Old Jan 30, 2004 | 12:41 PM
rapid_roy's Avatar
I'de say neither, go with the suspension but that wasn't your question.
I have an ITR tranny, ACT clutch and flywheel and that made more of a difference that my intake/exhaust did. Throw in some cams and I'de still go with the tranny.
The lack of an LSD is the GSR's biggest weakness, and adding one makes the grin factor go up higher, but that's just me. I am not concerned with how fast my GSR goes in straight line but how fast it goes around corners. It depends on what floats your boat.
Cheers,
Sean
Old Jan 30, 2004 | 12:42 PM
LX4CYL's Avatar
Default Re: Built Transmission or Built Motor (rapid_roy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rapid_roy &raquo;</TD></TR><TR><TD CLASS="quote">I'de say neither, go with the suspension but that wasn't your question.
Cheers,
Sean</TD></TR></TABLE>
I agree. Mods to your car have the following order when it comes to bang for the buck:
suspension
transmission
engine
tesw0n
Acura TL, RL & ZDX
Jan 2, 2019 12:32 PM
da9leo
Jun 26, 2007 08:18 PM
redex94
May 9, 2003 07:07 PM
gumbybum
May 6, 2003 12:32 PM
