HAMP filter for the K-Series
hamp is argueably one of the best oil filters out there however, there are so many different hamp filters out there. what is the right one and what is its part number?
well the small ones i have (filters that is) have part number H1540-PFB-004 so i just need to find some with "PLC" huh? the ones i have dont seem to be enough filter. i just wanna make sure that i have the RIGHT filter for the job you know?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr »</TD></TR><TR><TD CLASS="quote">
Hamp
H1540-PLC-004</TD></TR></TABLE>
i know you the man.....have you heard of H1540-POH-004? i heard that is the one.
Hamp
Hamp makes three. One a bit longer than stock (H1540-PR3-408), one the same size as stock (H1540-POH-004) and one a bit shorter than stock (H1540-PFB-004). The smallest one is the one that's reported to maintain oil pressure better during VTEC engagement.
H1540-PFB-004 works fine, not enough of a size difference to change the oil pressure.
Using these filters on a car that normally uses the Large filter (Ex: B18C) would keep the Spikes and Dips in Oil Pressure to a minimum, this is normally seen when VTEC engages and disengages.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimmyjames »</TD></TR><TR><TD CLASS="quote">Hamp makes three. One a bit longer than stock (H1540-PR3-408), one the same size as stock (H1540-POH-004) and one a bit shorter than stock (H1540-PFB-004). The smallest one is the one that's reported to maintain oil pressure better during VTEC engagement.</TD></TR></TABLE>
so then where does the H1540-PLC-004 fit up in this mix of filters?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackdc5 »</TD></TR><TR><TD CLASS="quote">how much do these HAMP filters go for and where can you get them? i've been using OEM honda filters@ 6-8$ each.</TD></TR></TABLE>
does anyone, who's commented in this thread, have any idea what HAMP stands for?
It Depends on where you buy them, most people buy in small quantities and resell them for about $12. We buy them in very large quantities and resell them at $6-7 depending on the amount bought by the customer.
Current Special on the Small HAMP's is 0-9 Filters $7 each, 10 or more filters and they are $6 each.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike M »</TD></TR><TR><TD CLASS="quote">
Current Special on the Small HAMP's is 0-9 Filters $7 each, 10 or more filters and they are $6 each.</TD></TR></TABLE>
what is the part number on those mike? are they specifically made for the k-series?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irrational »</TD></TR><TR><TD CLASS="quote">
what is the part number on those mike? are they specifically made for the k-series?</TD></TR></TABLE>
H1540-PFB-004
They work on all of the Honda Engines out there, K, B, F, etc. Series. They are well suited for use on the K Series engine which use the smaller filters than the F or B Series.
H1540-PFB-004
datamonkee
12
Jul 3, 2008 01:43 PM
piggydog
Jun 21, 2007 01:58 PM
2003, buy, civic, filter, h1540, h1540pfb004, h1540pfb408, h1540plc004, h1540pr3408, hamp, honda, plc, series
