Mechanical Window Problem
Old Jan 29, 2004 | 06:23 AM
boostsohfast's Avatar
Default Mechanical Window Problem
I messed my window up pretty bad the other day while trying to roll it down in the cold. There are two brackets at the bottom of the glass that make it go up and down. Well, I somehow managed to bend one of them and it popped out. I'm guessing that I have to take out the guts of the door and try to put that bracket back in place and then put everything back in?
If anyone has done this or whatever give me some advice.
P.S. Not having your window work really sucks.
Old Jan 29, 2004 | 06:53 AM
2000DX's Avatar
Default Re: Mechanical Window Problem (boostsohfast)
Yea, you're goin to have to take off ur door panels and then the plastic **** they have around the door itself. If your window is still on the tracks, you can just push the window up and then push it back down on the metal bracket and screw it back. If its bend, try to bend it back straight.
Old Jan 29, 2004 | 09:22 AM
Default Re: Mechanical Window Problem (00 Hatch DX)
I finished it up before. I took out all the crap in the door... it's only 6 bolts. I bent the bracket back the way it should be and popped it back into the bracket that the glass bolts to. I dunno if it will hold up but I guess I'll find out.
b.emerman
Honda CR-V & Element
Sep 5, 2015 04:36 PM
crxaddikt
14
Jun 21, 2011 11:32 AM
hugens26
26
Aug 31, 2010 10:18 AM
Sinner
Feb 2, 2006 06:30 PM
george34
Jul 28, 2005 08:49 PM
