Anyone running wilwood big brake conversion and 16" rotas?
I aint sure if their gonna fit, anyone running this setup here? The discs are 310mm, and ill be having 16" c8's.
Specs on the brakes are here:
http://www.wilwood.org/ds375.pdf
Cheers
Cheers
Are you going to be frequently tracking the car? If not the wilwood brake conversion is overkill for your purposes. Blank rotors, high-friction brake pads, and good brake fluid is all you need for street use
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matty T »</TD></TR><TR><TD CLASS="quote">I aint sure if their gonna fit, anyone running this setup here? The discs are 310mm, and ill be having 16" c8's.
Cheers</TD></TR></TABLE>
To answer you question, the Wilwood 12.2" kit does indeed fit behind the 16" Rota C8 (+40mm offset, I believe). I know this cause I've done it...
K7-1Ktrevor
13
Jan 16, 2009 08:05 PM
