Front sway set yes or no ?
not too long ago i posted a question on what type of front sway set i should get since i was able to get a rear set with a tie bar. since then i've been told that a front set isnt needed because the rear set will eliminate much of the understeer. i've also heard that because my stock front bar is too small, having a bigger rear bar will cause understeer. so the question is...should i get the front set? TIA
b18_spoon
Mar 22, 2009 06:54 PM
nek9
May 30, 2006 03:44 PM
