Cam timing question (milled)
Old Jan 28, 2004 | 09:21 PM
thad
Guest
Posts: n/a
Default Cam timing question (milled)
I've got a poorman's type R setup with a .028" mill off of the block, wondering if i need to run a cam timing other than stock, i've heard that a b16 with .030" off the head should run a half degree (advance?) to compensate. any related info would be helpful. TIA
Old Jan 29, 2004 | 04:25 PM
SC94DB8's Avatar
Default Re: Cam timing question (thad)
Did a little search for ya. I needed to know also.
Posted by Sleeper:
"Milling the head or decking the block decreases the distance between the cams and crank. The timing belt stays the same length, so for every .012" you remove, cam timing is retarded 1 degree. Advance accordingly to get back to true zero."
Hopefully someone can verify this. I have researched it before and this sounds right to me.
If this is correct than you need to advance your cam gears by 2.33 degrees.
Old Jan 29, 2004 | 05:50 PM
PHiZ's Avatar
Default Re: Cam timing question (SC94DB8)
Hrm, I would have though that milling is a function of how much slack your tensioner can compensate for....
-PHiZ
Old Jan 29, 2004 | 08:18 PM
Wes d's Avatar
Default Re: Cam timing question (PHiZ)
The cam tensioner takes up the slack but then it rolls your cam gears back too so you need to compensate by advancing the cams back to zero. You will see when you set your crank at TDC that your cam gears will be retarded in more ways than one. haha
Old Jan 30, 2004 | 12:57 PM
thad
Guest
Posts: n/a
i don't know why i couldn't find that when i searched, but thanx.
Old Jan 30, 2004 | 01:25 PM
servion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SC94DB8 &raquo;</TD></TR><TR><TD CLASS="quote">Did a little search for ya. I needed to know also.
Posted by Sleeper:
If this is correct than you need to advance your cam gears by 2.33 degrees.</TD></TR></TABLE>
Just to verify, this fix applies to the cam gears, not the distributor, correct?
Old Jan 30, 2004 | 02:11 PM
PHiZ's Avatar
Default Re: Cam timing question (servion)
Yeah, but is this trick to bring the timing back to the proper 16` BTDC, or is it a hack to "not ping" cause you've bumped your compression...
-PHiZ
Old Jan 30, 2004 | 07:36 PM
boostn420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion &raquo;</TD></TR><TR><TD CLASS="quote">
Just to verify, this fix applies to the cam gears, not the distributor, correct?</TD></TR></TABLE>
Once the cams are dialed in properly, which should be done with a cam degree wheel and a dial indicator, you should go back and set timing like normal since it moves with the cam.
Old Feb 2, 2004 | 12:00 PM
xsiv's Avatar
Just to verify, this fix applies to the cam gears, not the distributor, correct?</TD></TR></TABLE>You first set the cam timing on the gears, then the ignition timing via the distributer; So in this case for a head milled .028", I'd advance cam timing approximately 2 degrees, then reset my ignition timing back to 16 degrees.
Old Feb 4, 2004 | 04:33 PM
thad
Guest
Posts: n/a
you set both cams 2.3 degrees advanced right?
Old Feb 7, 2004 | 11:43 AM
nigel's Avatar
Default Re: Cam timing question (Wes d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes d &raquo;</TD></TR><TR><TD CLASS="quote">The cam tensioner takes up the slack but then it rolls your cam gears back too so you need to compensate by advancing the cams back to zero. You will see when you set your crank at TDC that your cam gears will be retarded in more ways than one. haha</TD></TR></TABLE>
ok so if the cam gears are retarded and advancing the 1 for every .012" brings them back to zero, that sill would not have any effect on the postition of the marks on the gears right? so if you have your cams advanced 2.3 degrees you'l still be looking at a seemingly misaligned belt, am i wrong, if not is there a way to fix it or do you just live with it.
Old Feb 10, 2004 | 03:20 PM
servion's Avatar
So, are those of us who have yet to purchase adjustable cam gears, well, screwed?
Old Feb 10, 2004 | 06:12 PM
thad
Guest
Posts: n/a
Default Re: (servion)
i don't think you have too much to worry about since the timing is retarded not advanced
bluedlude
Nov 9, 2006 06:31 AM
nigel
Feb 9, 2004 11:20 AM
JDMs1eeper
18
Aug 24, 2003 12:01 AM
JDMs1eeper
Aug 20, 2003 09:15 AM
[HrZn]4life
May 13, 2003 03:17 PM
