Dizzy?
Old Jan 28, 2004 | 09:07 PM
C8V6C's Avatar
Default Dizzy?
I don't have spark, and the B16 cranks but doesn't turn over
Have'nt checked fuel, but I got a new fuel pump like 2 months ago
Am I right guessin dizzy? And where can I find another one if needed?
Old Jan 28, 2004 | 09:40 PM
C8V6C's Avatar
Default Re: Dizzy? (C8V6C)
I'm sure this is a simple question, but got to make sure.......
Old Jan 28, 2004 | 11:40 PM
hondatim's Avatar
need to determine first if the ECU fuse in underhood fuse box is good. If it is not, replace it. If it is, then next need to determine if you have ignition coil failed or failed ignitor. I recommend that if you find that the coil or ignitor is failed, replace them both. Should typically be replaced as pair anyway. This saves headaches later, trust me.
Start diagnosis on these things first and let us know your results...
Old Jan 29, 2004 | 07:32 AM
mmuller's Avatar
Mad Scientist
Default Re: Dizzy? (hondatim)
also check main relay
Old Jan 29, 2004 | 09:02 PM
hondatim's Avatar
Default Re: Dizzy? (mmuller)
good thought mmuller.
this could also cause a no spark issue if ECU can't power up. If, however, you are checking ignitor signals to and from ignitor and do not get signal from ECU to ignitor, then you may have bad main relay as mmuller suggested.
Old Jan 29, 2004 | 11:18 PM
C8V6C's Avatar
lol, simple problem, like always
I took the cap off and tightened everything again and it seemed as though the ground wire on top was a little loose
tightened it up, and runs beautiful, as always, lol
Thanks guys
TheWhopper
May 8, 2019 05:59 AM
stevejames
Nov 24, 2016 01:23 PM
panda teggy
11
Jul 6, 2011 01:18 PM
Ep1dem1c
Jul 3, 2007 06:49 AM
mihaelrosas
Jun 8, 2007 04:27 PM
