N2O on a D15B7
wanted to have some with my stock motor before i put in the GSR. just wondering what's a safe and powerful nitrous shot for the D15. any time slips or info would be much appreciated, thanks!
n2o is perfectly safe its idiots that think theyre living in t.v. land (**** and furious) that blow there **** up. 50 shot should be fine. time wise with the 1.5 you should pick up about a half sec. in the 1/4. hit the nawz yo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95cxhatch »</TD></TR><TR><TD CLASS="quote">the only safe way to use N2O .....is to not use the **** at all!</TD></TR></TABLE>
Ignorant *** comment of the day award. I run a turbo at 8psi, which is like a constant 75-85 shot all day long with no problems. How is running a 50 shot once a week going to put any more stress on the motor than my turbocharger which has been running strong for months on end?
you are an idiot
you are an idiot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illicon2003 »</TD></TR><TR><TD CLASS="quote">Nitrous is a problem because you run SUPER lean on it. </TD></TR></TABLE>
Who does?? Gotta keep the fuel system up to par with the N20 setup. If your doing it correctly you should not be running lean.
and then you get 16.28 in the 1/4.
I ran a 75 zex dry shot into my d15b7 and I ran 15.8 in the 1/4... it was more fun with that motor to hit it on the street then at the track. If you take it down to many times in a night detonation may occur. It's swapped it a 4 door auto now and runs great still to this day.... I say do it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">
yup...and i got it without CHEATING which is all that N2O is!!!!!!
</TD></TR></TABLE>yup...and i got it without CHEATING which is all that N2O is!!!!!!
yup...and i got it without CHEATING which is all that N2O is!!!!!!</TD></TR></TABLE>
Not really...its an inexpensive way to make your car faster...
I suppose turbos are cheating too then.
75-shot dry should be safe on the street assuming you do not floor it for a full 1/4 mile.
On the track, you should keep it at 55-shot (if dry) to be safe.
Anyway, that's my experience with nitrous.
