Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
spark plugs VS coil packs
Old Jan 28, 2004 | 08:36 PM
memphisraines26's Avatar
Default spark plugs VS coil packs
I've read about coil packs for each plug area but what is the differnce than the normal spark plug setup? does it spark harder and faster? should i upgrade my 96 2.5 with better plugs, wires, or coil conversion?
Old Jan 29, 2004 | 06:20 AM
RangerJoe's Avatar
if you have plugs, keep them. coil packs are not very good when you get high in the revs, they start skipping, thus making engines very rich. if you have coilpacks, see if you can find some places to get better ones.
Old Jan 29, 2004 | 03:42 PM
GreenBean's Avatar
Default Re: (RangerJoe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RangerJoe &raquo;</TD></TR><TR><TD CLASS="quote">coil packs are not very good when you get high in the revs, they start skipping, thus making engines very rich</TD></TR></TABLE>
Why then do the
91-04 NSX, 96-04 RL, 3.2 96-03 TL, 01-04 MDX, 02-04 RSX, 04 TSX, and some Honda equiped V-6 engines have them???
Modified by GreenBean at 4:47 PM 1/30/2004
Old Jan 29, 2004 | 06:40 PM
Default Re: (GreenBean)
I didnt think ALL V6 hondas have coil packs but I've noticed the newer models like the RSX have them. Just wondering if any advantages for converting to them. I would like to know what I could do to produce more spark to be more efficient burn. thanks
Old Jan 30, 2004 | 01:17 PM
GreenBean's Avatar
Default Re: (memphisraines26)
After talking with some of the more experienced technicians at work we concluded this...In no particular order.
1-No distributor assembly=no worn distributor, or related internal parts, no worn button, no worn drives, no worn rotor buttons,
2-No resistance differences for the plug wires since they are not there,
3-Consistant firing directly from the ecu,
4-Locating sensors that used to be in the distributor assembly to better locations on the engine, or in the engine,
5-Consistency
Hope that helps, as for a company that can replace a distributor for coil packs I do not know, but there was a white 92-95 Hatchback at NOPI last year that had a setup with 4-NSX coils firing in his built GS-R engine, running like 26lbs or something...It was pretty sick to see it.
Old Jan 30, 2004 | 07:07 PM
well thanks for the insight. I wonder if nogoly would have any to convert. I want to pioneer the G25 to see what I can make of it. I know a lot of 2.5TLs and Viogrs that would benifit from it. thanks
anything eslse?
Old Jan 30, 2004 | 08:00 PM
GreenBean's Avatar
I wish somebody would make a header for that 5-cylinder...There's mad torque there...
Old Feb 1, 2004 | 05:49 PM
Yeh i know. I wish the acura luxo had more aftermarket for the 1st gen.
Dc5Typ3S12
Apr 3, 2008 04:35 AM
mike93eh2
Sep 10, 2007 10:38 PM
gottagofaster
Oct 22, 2005 04:50 PM
Fordman50
Dec 12, 2003 09:49 AM
