JDM ITR tranny (4.785 final)....big difference compared to the USDM Tranny???
Old Oct 4, 2001 | 12:30 PM
Petah's Avatar
Default JDM ITR tranny (4.785 final)....big difference compared to the USDM Tranny???
In a weeks time, i will be installing a 99 USDM ITR swap into my 92 EG hatch. At the shop where i am getting the work done, they happen to have a JDM ITR tranny with the 4.785 final. Will there be a huge difference in the 2 trannies? Is it worth the extra cash to have them install the JDM one?
Old Oct 4, 2001 | 12:36 PM
Jason's Avatar
Default Re: JDM ITR tranny (4.785 final)....big difference compared to the USDM Tranny??? (eg-six)
There is no such beast as a 99 USDM ITR...we only had them 97-98 and 00-01...
the final drive is for quicker acceleration, goes through the gears quicker...
Old Oct 4, 2001 | 12:38 PM
Petah's Avatar
Default Re: JDM ITR tranny (typer98)
Well i am not sure about the States, but here in Canada, there is a 99 for sure.
Old Oct 4, 2001 | 12:40 PM
Jason's Avatar
Default Re: JDM ITR tranny (eg-six)
that is correct...
Old Oct 4, 2001 | 12:45 PM
FAST4DR's Avatar
What are they wanting for the 98 Spec tranny?
Old Oct 4, 2001 | 12:49 PM
Mike M's Avatar
Founding Member
Default Re: JDM ITR tranny (FAST4DR)
As long as its not too much more and the tranny is in just as goo dhsape then I would go for it, As long as its a 98 spec tranny.
Old Oct 5, 2001 | 05:55 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
nah, keep your $$$ and the stock tranny. when you get up money and want to upgrade, swap in a clutch type lsd, 4.93 final, flywheel etc.....
Old Oct 5, 2001 | 05:59 AM
Back in Black's Avatar
Rather OG
Huge difference...much quicker acceleration/proceeds through gears faster!!! (ie: what the other Jason said)
DV- who hopes to have a JDM or Spoon tranny in the future
[Modified by Darth VadeR, 10:01 AM 10/5/2001]
Old Oct 5, 2001 | 10:42 AM
PrjctDC2-R's Avatar
New User
Hey EG-Six, do you ever go to the weekend runs in ottawa?
Old Oct 5, 2001 | 11:44 AM
97ITR217's Avatar
Hey EG-Six
Which shop do you go to? I'm in Ottawa too. Maybe we could meet up sometime.
Old Oct 5, 2001 | 11:51 AM
Katman's Avatar
It's a nice change from the normal 4.40 final drive.
You'll notice the difference right off the bat - it's not some minute little upgrade.
Acceleration is greatly improved along with about 15% of more torque too.
If you do get this 4.7 tranny, I suggest you get a lightened flywheel also - man..lightened flywheels should come standard on every Honda!
Old Oct 5, 2001 | 11:56 AM
betsuni's Avatar
Default Re: JDM ITR tranny (Katman)
hey katman, do you think getting an itr tranny for my ls is good or spend the money elsewhere?
Old Oct 5, 2001 | 12:01 PM
HX_Guy's Avatar
Default Re: JDM ITR tranny (betsuni)
Yep...Im sure there is quite a bit of differance.
Going from stock tires to 205/40-16s changed the final drive from 4.40 to 4.59 and I can tell a differance in that..so Im sure a differance from 4.40 to 4.78 will be quite noticable.
Old Oct 5, 2001 | 12:07 PM
HX_Guy's Avatar
Default Re: JDM ITR tranny (HX_Guy)
...or get the 4.785 FD and some 205/40-16s and you'll end up wit ha Final Drive of 4.975!
That will be a HUGE improvment
Old Oct 5, 2001 | 12:27 PM
Sam's Avatar
Sam
Does the wheel size affect the final drive ratio? A smaller wheel increase the findal drive ratio??
Old Oct 5, 2001 | 12:32 PM
Katman's Avatar
yah it's good..cuz not only will it help acceleration..but if you ever upgrade to lets say, the dreaded LS/vtec setup or even a B16A....all you need is the long block...not the whole engine+trans.
HX_Guy's Avatar
Default Re: JDM ITR tranny (Sam)
Yes it does.
Final Drives are "rated' with a stock size diameter. In alot of cases the stock diasize is 23.44" (195/55/15)
If you were to use 205/40-16s..the diameter changes to 22.46"...a whole inch smaller...which in turn changes the final drive from 4.40 to 4.59.
Old Oct 5, 2001 | 12:34 PM
Katman's Avatar
it sure does..
the JDM 98 ITR has a 16 wheel w/the 4.7 fd for a reason
ITRbroham's Avatar
shit post warrior
Although I didn't drive the car, I rode in yeahls' ITR equipped with JDM final drive at the ITR Expo and even from the passenger's seat I could tell that the car pulled alot harder when the driver got on the throttle. I was impressed when exiting turns how fast the car was and there is a noticeable difference!
Old Oct 5, 2001 | 12:37 PM
Type Goch's Avatar
New User
Default Re: JDM ITR tranny (ITRbroham)
yeah ive noticed that too LL..but doesn he also have like a GSR 3rd 4th gear or soemthing?
Old Oct 5, 2001 | 12:40 PM
ITRbroham's Avatar
shit post warrior
Default Re: JDM ITR tranny (Type Goch)
His car is stock except for the JDM FD and springs. Yeahls got skills!
Old Oct 5, 2001 | 12:41 PM
Katman's Avatar
98 JDM DC-2.R has ITR/B16 1-3 ratios and GSR/Si-G 4+5th ratios.
[Modified by Katman, 1:42 PM 10/5/2001]
Old Oct 5, 2001 | 12:47 PM
ITRbroham's Avatar
shit post warrior
Whut about for the 2000-01 models?
Type Goch's Avatar
New User
dont forget the GReddy, but i think he DOES have one of the GSR gears...well i think thats what he said.
Old Oct 5, 2001 | 12:50 PM
ITRbroham's Avatar
shit post warrior
I didnt know that.....sounds like yeahls tho!
