aem regulator. which oriface for 255lph and 440cc?
Old Jan 28, 2004 | 01:35 PM
BoostedD15B7's Avatar
Default aem regulator. which oriface for 255lph and 440cc?
Just got my AEM regulator, and it says that the different orifaces are used to match fuel pump output for bigger pumps. Which should i use for a 255 walbro intank with 440cc dsm injectors.. .100", .150", or the .200". I dont know if i should use the smallest one or the middle size.
Old Jan 28, 2004 | 03:56 PM
come on. Someone out there has to have one of these.
Old Jan 28, 2004 | 04:03 PM
Sonny's Avatar
Default Re: aem regulator. which oriface for 255lph and 440cc? (BoostedD15B7)
I did it and used the smallest one.
Sonny
Old Jan 29, 2004 | 08:02 AM
Rtype16's Avatar
Default Re: aem regulator. which oriface for 255lph and 440cc? (Sonny)
You can use teh smallest one, but when you back off the throttle you may have some pressure spikes I would suggest just to open it up and run the .2 orifice and than you won't have to worry. Remember after you change it check fuel pressure again.
Old Jan 29, 2004 | 08:18 AM
PM-Performance's Avatar
Default Re: aem regulator. which oriface for 255lph and 440cc? (Rtype16)
use the middle one, the 255 pump will be too much for the smaller one and you will eventually have probs.i had random missifres becuase of it
Old Jan 29, 2004 | 04:57 PM
cool i was thinking go with the middle one too. Will it affect anything, besides make the adjustment screw more sesative?
Old Feb 1, 2004 | 11:03 PM
Rtype16's Avatar
Default Re: (BoostedD15B7)
No. It will just make the adjustment screw more sensitive to changes depending on the fuel pump.
c-techracing
Feb 25, 2008 11:36 PM
OMGWTFBBQ!
Jan 24, 2007 05:28 PM
Replica
Aug 28, 2003 05:37 PM
b16 matt
Mar 13, 2003 07:30 AM
Firedrake
Jul 2, 2002 06:02 PM
